-JR- |
Life goes faster at 150MPH ![]() ![]() Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 ![]() |
I got in my 914 for the first time yesterday and I've been trying to figure out how to adjust the dang drivers seat forwards and backwards...
I'm not sure what the pull up handle does on the side of the seat, but it doesn't seem to want to make it move. The passenger seat has a handle that sticks out the front from one of the sides of the seat track, but the drivers side has no handles or nothing out the front of it. Thanks! -JR- |
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Ok..the handle on the side is for seat rake/angle. When you pull that up your seat will be able to tilt back/forth. The adjustment for forward/backward is on the front of the seat. There should have been a handle there with like a big O to grab onto. These break off very easily. If yours is missing it is obviously broken off (sounds like your passenger side has it?)?. If this is the case get a flashlight...look under the seat from the front...find where it is broken off and depending on where/how it broke off you might be able to use one of your handy tools to pull the adjuster and move the set. Might have to 2-person it if it is broken way far back.
You'll understand once you look under the seat on both sides along the rails. Then go to the classifieds and ask if anybody has one they could part with!. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:44 AM |
