> help with oil leak, 914 case of unknown history
Al Meredith
post Oct 18 2022, 12:42 PM
I am building a 2056 for a friend and it is mounted on my run up stand and fires right up as expected but has a serious oil leak on the 3/4 side . Not the filter ,not the oil cooler, not the pressure switch. I replaced the push rod tubes and installed Vuton O rings. Oil is coming from above the air diverter plate above the pushrod tubes . The diverter plate is filling it's pockets with oil. I removed the plate and see no Leake.I removed the spark plugs and turned over with the starter motor and got 25PSI {I have a direct reading guage installed) can see no leaks . When running I'm pumping over 50PSI . NOW I NEED SOME HELP .Can the small "freeze plug in the main oil passage be leaking? I have NEVER had a plug leak and with checking some other builders including my Son who has built many T4 s for his own race car and many others . If this is a problem can I repair with "JB" weld? Please help, I hate to have to take this apart and start over. AL
TheCabinetmaker
post Oct 18 2022, 05:43 PM
I drive my car everyday
Oil pressure switch?
Oops. Missed it!
- Lo-Fi Version Time is now: 31st October 2024 - 07:29 PM
