help with oil leak, 914 case of unknown history |
Al Meredith |
Oct 18 2022, 12:42 PM
Senior Member Group: Members Posts: 969 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I am building a 2056 for a friend and it is mounted on my run up stand and fires right up as expected but has a serious oil leak on the 3/4 side . Not the filter ,not the oil cooler, not the pressure switch. I replaced the push rod tubes and installed Vuton O rings. Oil is coming from above the air diverter plate above the pushrod tubes . The diverter plate is filling it's pockets with oil. I removed the plate and see no Leake.I removed the spark plugs and turned over with the starter motor and got 25PSI {I have a direct reading guage installed) can see no leaks . When running I'm pumping over 50PSI . NOW I NEED SOME HELP .Can the small "freeze plug in the main oil passage be leaking? I have NEVER had a plug leak and with checking some other builders including my Son who has built many T4 s for his own race car and many others . If this is a problem can I repair with "JB" weld? Please help, I hate to have to take this apart and start over. AL
Superhawk996 |
Oct 20 2022, 12:02 PM
914 Guru Group: Members Posts: 6,502 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I have a set of 96mm AA P&C’s sitting on sideline - guess they will get extra close eye when they get used. Hopefully AA Pistons will stand behind them if porosity or crack is found, documented, and brought to their attention. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:25 PM |
