2.0 D-Jet Fuel Injectors, Anybody got a good source for new injectors? |
Craigers17 |
Mar 10 2020, 06:28 PM
Senior Member Group: Members Posts: 807 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I raised this question in another thread, but thought it would get more feedback in it's own topic. I am trying to do a partial refresh of my fuel injection/intake system, and, upon digging a little, found that I have 3 different kinds of injectors...at least 2 of them probably not designed for a 2.0 engine.
I've been searching for a good source for new injectors, and am running into a lot of dead ends. Thanks to a member here, I know I could send my 2.0 injectors to Mr. Injector for refurbishing, and I probably will. However, I'd like to then use those 2 as spares. I have found 2 BOSCH 0280150019 injectors which should be the correct, but discontinued injectors, but they are incredibly expensive. Then I thought I found another solution from GP Sorensen that appears to be the correct part for 73/74 2.0. It is part # 800-1061N and I THOUGHT it was available at AutoZone and roughly $85/EA. However, upon selecting and trying to add to the cart, it said they are currently unavailable. I've also seen a part #FJ67 from Standard Motor Products, but don't really know if that's a direct replacement. So.....I'm posting this here to see if anyone has a good source for new 2.0 injectors? Or, if anyone has used any of the above options with success? Any feedback would be great. Thanks, -Craig I know this will probably end up in a carb vs OEM FI vs aftermarket FI debate, but I really am just interested in a source for 2.0 injectors for D-Jet. I really do appreciate all the reasons for different choices, but I'm gonna try to give this one a shot first. |
Craigers17 |
Apr 30 2020, 04:04 PM
Brief Follow-up on the FJ-67 injectors. I have installed these and they are working great. The only thing I noticed was that it seemed to me that the tip of the FJ-67 injector is a little more "snub-nosed" than stock and, thus, doesn't seem to protrude into the intake quite as far. That said, it seems to seal up well, with no issues.
Finally, I also sent 4 of the stock Green injectors to Mr. Injector for service. They were the Bosch P/N that ends in 019 mentioned previously. Only 2 were serviceable, but I just got them back with the flow report. I thought it was worth including that report to compare apples to apples. You can view the other report a few posts previous to this one. Here's the report: |
sithot |
Oct 21 2022, 12:25 PM
Member Group: Members Posts: 447 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Read the entire thread.
Lo-Fi Version | Time is now: 23rd December 2024 - 03:21 AM |
