Carbs or Fuel injection ? |
ILM914 |
Oct 24 2022, 09:51 AM
Member Group: Members Posts: 98 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi folks a 914"expert said carbs will burn the valves on a 914 and not run well. Is this true? is the fuel economy worse when using duel carbs? Would you run orig fuel injection on a 2.0 or carbs thank you, Joe
sithot |
Oct 27 2022, 06:13 AM
Member Group: Members Posts: 447 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
I'll do whatever I can to keep the FI on mine going.
OTOH, for those of you with a real 6 or 6 conversions running Weber carbs, the full radius trumpets in the link really work. I learned of them from Paul Abbott @ Performance Oriented. Paul is a guru on Webers. He recommended these to Ed Mayo (PCA Ed Mayo) to deal with a running/tuning issue. He built a pair of 42mm for me. They're on a "warmed over" 2.7. https://www.dellorto.co.uk/shop/car-accesso...mm-x-50mm-long/ Paul's work in progress: Completed: The car now running a Clewett Engineering crank fire ignition. No further distributor rebuilds. The car had one done by "the best" before I owned it. It's a museum piece now. These coils can fire a fat mixture and the car which was already strong is more so now. Timing is spot on 100% of the time. It starts easier too. |
930cabman |
Oct 27 2022, 04:52 PM
Advanced Member Group: Members Posts: 3,523 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I'll do whatever I can to keep the FI on mine going. OTOH, for those of you with a real 6 or 6 conversions running Weber carbs, the full radius trumpets in the link really work. I learned of them from Paul Abbott @ Performance Oriented. Paul is a guru on Webers. He recommended these to Ed Mayo (PCA Ed Mayo) to deal with a running/tuning issue. He built a pair of 42mm for me. They're on a "warmed over" 2.7. https://www.dellorto.co.uk/shop/car-accesso...mm-x-50mm-long/ I'll bet she rocks it out Paul's work in progress: Completed: The car now running a Clewett Engineering crank fire ignition. No further distributor rebuilds. The car had one done by "the best" before I owned it. It's a museum piece now. These coils can fire a fat mixture and the car which was already strong is more so now. Timing is spot on 100% of the time. It starts easier too. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:09 PM |
