> A question for you 6 owners, 914-6 Tune up
mr914
post Jan 28 2003, 05:32 PM
914 Hillbilly
How do you do a ignition tune up on a 6? (IMG:style_emoticons/default/huh.gif)
I see the dizzy way down there in the front of the motor...
Do you have to drop the engine out to get to it, or do you need to find an accomplished 12 year old?
How many have modified the firewall for access?
Robarabian
post Oct 27 2022, 08:17 PM
914 A Roo
Before you remove the dizzy, get your air compressor in there to blow out any dust / dirt that may fall in when you pull it.
Also, once the pulley is at TDC, look at the flywheel and make sure of the TDC marking there before you start trying to time things. Sometimes things are not aligned the way they should be.
Im considering a 123 ignition, but mine is not a factory 6 either...
mr914   A question for you 6 owners   Jan 28 2003, 05:32 PM
mskala   This topic has been :smash: over on another list...   Jan 28 2003, 06:49 PM
Brad Roberts   I was going to answer, but I can see I dont need t...   Jan 29 2003, 02:58 AM
J P Stein   Izat' an original 6 or one you can cut holes i...   Jan 29 2003, 03:54 AM
mr914   Thank you Mark for the informative post. Being a...   Jan 29 2003, 08:24 AM
mlindner   I like having the fire wall access panel. A must f...   Oct 27 2022, 02:02 PM
tpines   I like having the fire wall access panel. A must ...   Oct 27 2022, 09:01 PM
Robarabian   Before you remove the dizzy, get your air compress...   Oct 27 2022, 08:17 PM
infraredcalvin   Resurrected from 2003 guys…   Oct 27 2022, 08:32 PM
porschetub   Resurrected from 2003 guys… whats wrong with ...   Oct 27 2022, 10:11 PM
Cairo94507   I would not cut the firewall on an original 6; we ...   Oct 28 2022, 06:52 AM
Steve   When I had my 2.7, i installed a pertronix ignitor...   Oct 28 2022, 08:34 AM
Jett   FYI if anyone is interested… my mechanic/friend ...   Oct 28 2022, 10:00 AM
ClayPerrine   Porsche Classic now sells a cap and rotor set for ...   Oct 28 2022, 10:21 AM
fixer34   It has been many years since I set the timing on m...   Oct 28 2022, 10:49 AM
brant   So much easier I check it annually on the winter ...   Oct 28 2022, 12:55 PM
porschetub   So much easier I check it annually on the winter...   Oct 28 2022, 06:34 PM
gulf908   every time I have significant work done,I get my m...   Oct 28 2022, 11:25 PM
wonkipop   factory didn't mind doing it on their own GTs...   Oct 30 2022, 12:57 AM
jhynesrockmtn   I dropped the motor on my GT 6 Tribute and while i...   Oct 30 2022, 08:57 AM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 10:15 AM
