> A question for you 6 owners, 914-6 Tune up
mr914
post Jan 28 2003, 05:32 PM
914 Hillbilly
How do you do a ignition tune up on a 6? (IMG:style_emoticons/default/huh.gif)
I see the dizzy way down there in the front of the motor...
Do you have to drop the engine out to get to it, or do you need to find an accomplished 12 year old?
How many have modified the firewall for access?
fixer34
post Oct 28 2022, 10:49 AM
It has been many years since I set the timing on my -6, mainly because I drove it very little, but I do remember the process.
I switched to a Bosch 911T distributor 40 years ago because I was having trouble finding Marelli parts even back then.
Remove air cleaner.
set TDC mark on the flywheel for cylinder 1. you are using the case opening back by the transmission as you can't see the front pulley.
remove distributor, replace/gap points as needed, reinstall keeping rotor lined up with mark on distributor housing. snug the retaining bolt just enough to keep the distributor from rotating on its own, but you can move it in small increments with your hand.
Now the fun begins. Attach the timing light to plug wire 1, start the engine, let it warm up and have someone bring it up to 6000 rpm. this is best done by someone sitting in the driver seat.
Lean over the 3 open carb stacks with the engine screaming in your ear and check the timing mark with the light. If needed, reach down with your right hand and turn the distributor ever so slightly to adjust the timing. You probably have a 50-50 chance of picking the right direction. Be aware there is a fast moving alternator belt just inches from that hand.
Get the timing mark lined up with the pointer on the case and slowly tighten the retaining bolt. After each half turn, recheck the timing to make sure it hasn't moved.
Once it is set, take it back to idle, reinstall the air cleaner, and take it out for a drive.
mr914   A question for you 6 owners   Jan 28 2003, 05:32 PM
mskala   This topic has been :smash: over on another list...   Jan 28 2003, 06:49 PM
Brad Roberts   I was going to answer, but I can see I dont need t...   Jan 29 2003, 02:58 AM
J P Stein   Izat' an original 6 or one you can cut holes i...   Jan 29 2003, 03:54 AM
mr914   Thank you Mark for the informative post. Being a...   Jan 29 2003, 08:24 AM
mlindner   I like having the fire wall access panel. A must f...   Oct 27 2022, 02:02 PM
tpines   I like having the fire wall access panel. A must ...   Oct 27 2022, 09:01 PM
Robarabian   Before you remove the dizzy, get your air compress...   Oct 27 2022, 08:17 PM
infraredcalvin   Resurrected from 2003 guys…   Oct 27 2022, 08:32 PM
porschetub   Resurrected from 2003 guys… whats wrong with ...   Oct 27 2022, 10:11 PM
Cairo94507   I would not cut the firewall on an original 6; we ...   Oct 28 2022, 06:52 AM
Steve   When I had my 2.7, i installed a pertronix ignitor...   Oct 28 2022, 08:34 AM
Jett   FYI if anyone is interested… my mechanic/friend ...   Oct 28 2022, 10:00 AM
ClayPerrine   Porsche Classic now sells a cap and rotor set for ...   Oct 28 2022, 10:21 AM
fixer34   It has been many years since I set the timing on m...   Oct 28 2022, 10:49 AM
brant   So much easier I check it annually on the winter ...   Oct 28 2022, 12:55 PM
porschetub   So much easier I check it annually on the winter...   Oct 28 2022, 06:34 PM
gulf908   every time I have significant work done,I get my m...   Oct 28 2022, 11:25 PM
wonkipop   factory didn't mind doing it on their own GTs...   Oct 30 2022, 12:57 AM
jhynesrockmtn   I dropped the motor on my GT 6 Tribute and while i...   Oct 30 2022, 08:57 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 10:17 AM
