Blinkeer wiring? |
Blinkeer wiring? |
torakki |
Oct 27 2022, 05:00 PM
Member Group: Members Posts: 55 Joined: 5-October 18 From: Nor Cal Member No.: 22,545 Region Association: Northern California |
'74 2.0l been sitting for a while and turn signals didn't work. After playing around with them, they now work but the top light in the fuel instrument flashes even when the turn signals are in the center (off) positon. Where are the 12 volts coming from? I've scanned the diagrams and all seems correct. Any ideas?
Thanks |
torakki |
Oct 28 2022, 03:31 PM
OK. Clay, you're on to something. First, I checked the switch on the hand brake. No difference, in or out. Then, jacked up the car and pushed in the little plunger (maybe 1/8"). A little hard to push in and stayed in. Light still flashing but when I release the hand brake, it goes off now.
Lockwodo - I recently bleed all the brakes and slowly getting a good pedal. I will continue to bleed since the hand brake wont stop the car from rolling. I think there's a stuck piston or two. Could it also be that I have the wrong relay for the blinkers? I found this one in my box of old parts. It matched the socket it goes in (blades, not pins). All the other relay plugs are pins. Thanks for the responses. |
Lo-Fi Version | Time is now: 6th January 2025 - 10:01 AM |
