> A question for you 6 owners, 914-6 Tune up
mr914
post Jan 28 2003, 05:32 PM
914 Hillbilly
How do you do a ignition tune up on a 6? (IMG:style_emoticons/default/huh.gif)
I see the dizzy way down there in the front of the motor...
Do you have to drop the engine out to get to it, or do you need to find an accomplished 12 year old?
How many have modified the firewall for access?
brant
post Oct 28 2022, 12:55 PM
So much easier
I check it annually on the winter maintenance list
porschetub
post Oct 28 2022, 06:34 PM
QUOTE(brant @ Oct 29 2022, 06:55 AM) *
So much easier
Nice ,cut mine the same way but still tight and some danger when moving the dizzy,if you go to pointless ignition you have removed 2 adjustments and if you have a worn drive shaft bearings another problem solved .
First job after getting my car running was to cut the "hole" for tuning ,no regrets but sad to do it on a real "6" .
mr914   A question for you 6 owners   Jan 28 2003, 05:32 PM
mskala   This topic has been :smash: over on another list...   Jan 28 2003, 06:49 PM
Brad Roberts   I was going to answer, but I can see I dont need t...   Jan 29 2003, 02:58 AM
J P Stein   Izat' an original 6 or one you can cut holes i...   Jan 29 2003, 03:54 AM
mr914   Thank you Mark for the informative post. Being a...   Jan 29 2003, 08:24 AM
mlindner   I like having the fire wall access panel. A must f...   Oct 27 2022, 02:02 PM
tpines   I like having the fire wall access panel. A must ...   Oct 27 2022, 09:01 PM
Robarabian   Before you remove the dizzy, get your air compress...   Oct 27 2022, 08:17 PM
infraredcalvin   Resurrected from 2003 guys…   Oct 27 2022, 08:32 PM
porschetub   Resurrected from 2003 guys… whats wrong with ...   Oct 27 2022, 10:11 PM
Cairo94507   I would not cut the firewall on an original 6; we ...   Oct 28 2022, 06:52 AM
Steve   When I had my 2.7, i installed a pertronix ignitor...   Oct 28 2022, 08:34 AM
Jett   FYI if anyone is interested… my mechanic/friend ...   Oct 28 2022, 10:00 AM
ClayPerrine   Porsche Classic now sells a cap and rotor set for ...   Oct 28 2022, 10:21 AM
fixer34   It has been many years since I set the timing on m...   Oct 28 2022, 10:49 AM
brant   So much easier I check it annually on the winter ...   Oct 28 2022, 12:55 PM
porschetub   So much easier I check it annually on the winter...   Oct 28 2022, 06:34 PM
gulf908   every time I have significant work done,I get my m...   Oct 28 2022, 11:25 PM
wonkipop   factory didn't mind doing it on their own GTs...   Oct 30 2022, 12:57 AM
jhynesrockmtn   I dropped the motor on my GT 6 Tribute and while i...   Oct 30 2022, 08:57 AM
- Lo-Fi Version Time is now: 15th January 2025 - 10:03 AM
