> New 2.8 Liter Six for the Racecar, I'll be asking a bunch of Conversion Questions
motorvated
post Oct 21 2022, 03:28 PM
The first question I have is related to modifications to the engine shelf pieces required for the 6-cylinder conversion. I noticed the Patrick Motorsports sells an expensive engine shelf kit for the 6-cylinder conversion. But, since the 6-cylinder is going into a Racecar, can I just cut out the entire engine shelf to maximize the available space in the engine compartment? Or, has anyone made a template that can be used to modify the 4-cylinder engine shelf to accommodate the 911 engines? I'd like just to remove the shelf parts if they are not needed. Thoughts on this? How do you other racers handle this. Many more questions to follow. I know there are many conversion threads out there, but it's hard to weed through them to see if they address the question(s) that I have. Plus most of Tigre are for street car conversions, not race cars.
Mike S.
brant
post Nov 1 2022, 03:47 PM
I dump my 2 front coolers through the wheel wells also
I wondered in the beginning if it would impact brake temps...
my mechanic told me no...
said that 200 degree air from the cooler was not going to hurt 600 degree brake temps...
turns out he was correct.
I've never had brake temp problems.
in fact if anything I have too low of a brake temp problem
I started measuring my rotors temps..
had to remove all of my brake cooling to get them to come up to a higher temp... operating range...
in fact had to lower my pad compound to a lower operating range just to get the temps up
had to lower 2 designations on pad material as the first step still didn't bring my brake temps into operating range....
so at least on my car... getting enough temp into the brakes was my problem and not overheating them....
I know I'm running a smaller motor (2.0) than a lot of others do...
I realize that with a much bigger motor, my top speeds would increase that that would also bring my brake temperatures up...
but at least in my application, the oil cooling air... does not negatively impact brake temps
motorvated   New 2.8 Liter Six for the Racecar   Oct 21 2022, 03:28 PM
stownsen914   You mean the engine tin, or the horizontal shelf t...   Oct 21 2022, 06:25 PM
GregAmy   Ditto on my /4: no tin surround, it's all trim...   Oct 22 2022, 07:40 AM
Charles Freeborn   Mine has all the tin removed too - "firewall...   Oct 22 2022, 09:03 AM
motorvated   Mine has all the tin removed too - "firewall...   Oct 22 2022, 10:48 AM
brant   I’m not running any engine shelf or tin either. ...   Oct 22 2022, 04:17 PM
motorvated   I’m not running any engine shelf or tin either....   Oct 23 2022, 06:23 AM
Charles Freeborn   I’m not running any engine shelf or tin either...   Oct 23 2022, 03:35 PM
BillJ   Many go with JB Racings distributor. Jbracing.co...   Oct 23 2022, 09:39 AM
motorvated   Many go with JB Racings distributor. Jbracing.c...   Oct 23 2022, 12:01 PM
brant   Many go with JB Racings distributor. Jbracing....   Oct 24 2022, 10:06 AM
infraredcalvin   My -4 has FAT 911 fan shroud with no additional ti...   Oct 23 2022, 12:08 PM
BillJ   Depending on where you want to drive the car be ca...   Oct 23 2022, 05:50 PM
infraredcalvin   You should also consider the stock location and s...   Oct 30 2022, 01:31 PM
motorvated   You should also consider the stock location and ...   Oct 31 2022, 08:25 PM
BillJ   Quick question. Why a 2.8? For most groups that ...   Oct 25 2022, 07:14 AM
motorvated   Quick question. Why a 2.8? For most groups that...   Oct 25 2022, 08:00 AM
Charles Freeborn   Quick question. Why a 2.8? For most groups tha...   Oct 27 2022, 09:14 AM
brant   Is it a hemmigway motor? Or 2nd guess. Matt in ca...   Oct 25 2022, 08:37 AM
BillJ   Makes sense and sounds like you have the perfect a...   Oct 25 2022, 07:19 PM
gms   engine shelf left in, no engine sheet metal instal...   Oct 26 2022, 11:59 AM
BadToTheBown   Mine is all removed, great access to everything......   Oct 27 2022, 11:56 PM
Krieger   On my 3.0 track car I run the stock tank with a co...   Oct 31 2022, 11:03 PM
brant   The motors create a lot of heat Your about to doub...   Nov 1 2022, 07:08 AM
motorvated   The motors create a lot of heat Your about to dou...   Nov 1 2022, 08:07 AM
campbellcj   I kept the shelf and tin in mine, and also the tru...   Nov 1 2022, 11:29 AM
brant   I dump my 2 front coolers through the wheel wells ...   Nov 1 2022, 03:47 PM
motorvated   I dump my 2 front coolers through the wheel wells...   Nov 3 2022, 07:14 PM
stownsen914   my mechanic told me no... said that 200 degree ai...   Nov 5 2022, 10:24 AM
mlindner   I have both the engine shelf and tin. But for bett...   Nov 4 2022, 06:22 AM
brant   I run a 901 instead of the 915 I ran my trans coo...   Nov 4 2022, 07:00 AM
Charles Freeborn   My front coolers and ducting for brakes. Don't...   Nov 13 2022, 10:18 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 12:28 PM
