speedometer cable replacement, any tricks? |
jfort |
Jan 12 2005, 03:33 PM
Senior Member Group: Members Posts: 1,146 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I did a search and didn't see anything. Probably too simple, but I can find a way to screw up the easiest task. I am looking at the factory manual. Replacing the speedo cable sounds easy but the pictures are not too good. Can someone describe the process? My gauges are out. Disconnect from transmission and pull it out? Fish the new one from rear to front?
jfort |
Jan 17 2005, 09:54 AM
I ordered and received from PP speedo cable # 914-641-111-00. At the transmission end of the cable there is no threaded fitting as appears in the factory manual. See picture attached. What am I missing? How is the cable secured at that end?
Thanks for your help! Attached File(s) speedo_cable_connection.pdf ( 72.15k ) Number of downloads: 194 |
Lo-Fi Version | Time is now: 5th February 2025 - 08:53 AM |
