blabla914 |
I like primer ![]() ![]() Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None ![]() ![]() |
The short version.
I just want to check to be sure that the bolt spacing on 914 rear calipers is the same as early (we'll say '65-73 or so) 911. Thanks for your help. Kelly The long version. I have '69E front struts and brakes. They were very cheap and work great. I am currently using them with 914-6 rear rotors (yes the car is 5 bolt) and 914-4 rear calipers. I have an adjustable bias valve. My problem is I used to have a nice bias adustment range with the stock 4 cylinder brakes. Now the bias, even with the valve closed or removed is OK for the street, but I like a little more rear bias for autocross. Yes I realize you can get yourself into a mess in a hurry this way. I would also like to go to wider tires on the rear than in the front and my experience is this will make my bias problems worse. The solution I'm looking at is using '69 911T/912 rear calipers. These have the larger pad area to match my '69E fronts, but will allow the use of my solid 914-6 rear rotors. It also means that I could swap back to my 914-4 rear calipers to use my e-brake when driving on the street if necessary. This is important to me as I drive the car all summer, everyday and I may need an e-brake if inspection laws change. I would also avoid having to turn down '69 and up vented rear rotors to the 286mm diameter. I have read elsewhere on the forum vented rear disks aren't necessary with a small six like my 2.0E. Who out there has done this conversion? Anything I am missing? Thanks for your help. Kelly |
blabla914 |
Mueller,
Thank you for not only answering my question, but reminding about the -4 front caliper swap. I read about that a long time ago and totally forgot about it. Since I happen to have a perfectly good set of -4 front calipers sitting on the shelf and the pad availability for them looks good I think that is what I'll do. You saved me a bunch of time and money looking for 911 units. That stoptech article is a very good summary of what's going on. Of course these cars with a bit more weight on the back use the rear brakes a bit more. Porsche did use vented rears on competition 914-6's but I believe it's mainly because they had them from the 911, turning a few mm off the OD wasn't a big deal for them, and heat management for a 24hr endurance car is a lot different than a sprint race car. I'll also add that a friend of mine is running stoptech's on the front of a fairly heavily modified 996 turbo with stock rears and they work very well for him. Thanks again, Kelly |
Lo-Fi Version | Time is now: 26th June 2024 - 12:35 AM |
