D-Jet vacuum hose question, Which hose, or Both? |
Olympic 914 |
Feb 10 2017, 07:45 AM
Group: Members Posts: 1,710 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Just finished up installing all the FI wiring harness and the vacuum hoses and now the engine compartment looks like a bowl of Spaghetti.
This engine started out as a 73 1.7 with the stock FI and I converted everything to a 2.0 system. I did use some of the original 1.7 parts as they were the same for both engines. But all the 2.0 FI parts ( throttle body, plenum, air filter housing ,etc.) where cobbled together from fleabay purchases and I am not sure what years those parts were from. Also used the original 73 1.7 FI wiring harness and ECU and had to make a couple extensions to get everything to hook up. Not much problem there, (except for trying to connect those ground wires under the plenum. ) Now to the question, I was using Bowlsby's vacuum diagram that is for a late 74 2.0 system and while hooking up the vacuum lines to the dizzy it seem that one line is no longer used. in the diagram above I have the green vacuum hose connected from the throttle body to the dizzy as shown by the Orange circles. I also have another vacuum port on my dizzy that I have connected to the second vacuum port on my throttle body shown by Blue circles. Should I have both of these hooked up? or do I disconnect the Black vacuum line as shown in Bowlsby's diagram and just plug the second port on the throttle body. This is what I have hooked up now. Is there a reason that the later versions did not have this second port hooked up? What benefits are there to using the second line to the dizzy vacuum canister? in picture below the green line from the throttle body is routed differently |
JeffBowlsby |
Dec 4 2022, 10:29 PM
914 Wiring Harnesses Group: Members Posts: 8,791 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Decel valve was added in 1972. Could be retrofitted to earlier cars.
Lo-Fi Version | Time is now: 9th January 2025 - 06:32 AM |
