Saturday, 5 April 2025 |
East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
I’ve been out of the 914 game for quite some time. The last 914 I built was back in 2006 and was quite a build. I’ve had about a dozen 914s over the years and my 2006 build was to be my ultimate 914 (for me at least). It was a GT flared 3.6 six conversion and was a great car. I sold it in 2015 and moved to other things. I’ve been getting the itch to build another teener for a while, but to go in a different direction. I’ve seen a couple Safari builds and that seemed interesting.
I picked up pretty well worn ‘72 914 for the base of my project. My plan is to build a budget conscious (it’s all relative) Subaru powered Safari mod. I plan to go with a normally aspirated 2.5 Subaru from a 1998 Forrester along with the Subaru tranny. I’ve been working on removing rust and getting the tub suitable for my plans. This will by no means be a concours resto type build, but should prove interesting. Here’s the base car being picked up for the project start ![]() I stripped it down and sold the engine and tranny (it was a partially completed V8 conversion). Then started cutting out rusted areas a welding in new metal. Some Radom rust repair pics in no special order…. ![]() Attached thumbnail(s) ![]() |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I am still in admiration with your fiberglass duct work on your silver six (avatar), but now, even more! (IMG:style_emoticons/default/pray.gif)
A few questions: What type of foam is this? What type of adhesive are you using to bond the foam pieces? What type of filler are you using? Are you putting any protective layer on the filler prior to laying the CF over? Are you using polyester resin with CF as you would for fiberglass? Would all of this buck preparation process be the same for fiberglass? I think this is such cool fabrication work! (IMG:style_emoticons/default/beer.gif) Sorry for all the question... (IMG:style_emoticons/default/rolleyes.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 5th April 2025 - 11:42 AM |
