Stereo questions, Battery and alternator issues |
Motosan |
Dec 13 2022, 01:01 PM
Newbie Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
Sorry if this has been covered before but just wanted to ask before I jump into this on my project.
The 914 I am restoring has a single din head unit that I have just decided to replace with a new unit. I would like to install a pair of speakers(using the 914 rubber speaker pods) and a very small amp in addition to the new head unit. The car already seems to drop voltage with any extra demand, so I’m trying to go about this the best way possible. Would upgrading the battery and running a separate fuse block be the best option? I was looking at an Odyssey pc925 as a possible option. Thanks! |
Mikey914 |
Dec 13 2022, 01:50 PM
The rubber man Group: Members Posts: 12,736 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it.
You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) |
Motosan |
Dec 13 2022, 02:04 PM
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it. You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) I included the led bulb replacements in my last order with you! I just received two very large boxes yesterday! Thanks!! |
sb914 |
Dec 14 2022, 08:36 AM
Surf Guru Group: Members Posts: 4,395 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it. You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) I included the led bulb replacements in my last order with you! I just received two very large boxes yesterday! Thanks!! Nice quiver ! |
Motosan |
Dec 15 2022, 11:54 PM
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it. You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) I included the led bulb replacements in my last order with you! I just received two very large boxes yesterday! Thanks!! Nice quiver ! Thanks! They are all fun in their own way. |
Lo-Fi Version | Time is now: 22nd November 2024 - 02:57 PM |
