> Clutch Problem, Adjustment Changes
Bruce Hinds
post Dec 30 2022, 09:20 PM
V-8 madness
I reinstalled the engine after a rebuild and for some reason that I can't figure out the clutch seems to go out of adjustment when the car warms up.
I park it and let it cool, the clutch works just fine. Pedal play and everything is normal until it warms up again. Seems to be a bit more play but when warm I can't get first or reverse with grinding. Starting in gear with the clutch in, the car still moves.
How can this be?
Bruce Hinds   Clutch Problem   Dec 30 2022, 09:20 PM
914Sixer   Did you replace the clutch fork pivot bushing and ...   Dec 31 2022, 09:08 AM
Bruce Hinds   Did you replace the clutch fork pivot bushing and...   Dec 31 2022, 10:08 AM
bdstone914   Did you connect the ground strap from thr trans to...   Dec 31 2022, 09:38 AM
Bruce Hinds   Did you connect the ground strap from thr trans t...   Dec 31 2022, 10:13 AM
bdstone914   Did you connect the ground strap from thr trans ...   Dec 31 2022, 10:33 AM
Bruce Hinds   [quote name='Bruce Hinds' post='3048368' date='De...   Dec 31 2022, 11:29 AM
914Sixer   Bushing tends to crumble under heat. I do not kno...   Dec 31 2022, 10:33 AM
Bruce Hinds   Bushing tends to crumble under heat. I do not kn...   Dec 31 2022, 11:27 AM
Superhawk996   Bushing tends to crumble under heat. I do not k...   Dec 31 2022, 12:30 PM
Bruce Hinds   [quote name='Bruce Hinds' post='3048382' date='De...   Dec 31 2022, 12:50 PM
Superhawk996   It was perfect before the engine rebuild, BUT ev...   Dec 31 2022, 01:04 PM
Bruce Hinds   It was perfect before the engine rebuild, BUT e...   Dec 31 2022, 01:31 PM
clarkcou   Thanks for the conversation Peter - actually went ...   Jan 2 2023, 01:11 AM
mgphoto   Could be loose motor mounts, it’s not the warm u...   Dec 31 2022, 07:39 PM
izaporsche   I reinstalled the engine after a rebuild and for ...   Jan 2 2023, 07:51 AM
Bruce Hinds   I reinstalled the engine after a rebuild and for...   Jan 2 2023, 10:43 AM
izaporsche   [quote name='izaporsche' post='3048765' date='Jan...   Jan 2 2023, 07:20 PM
Bruce Hinds   [quote name='izaporsche' post='3048765' date='Ja...   Jan 2 2023, 08:06 PM
- Lo-Fi Version Time is now: 21st December 2024 - 10:58 PM
