> Clutch Problem, Adjustment Changes
Bruce Hinds
post Dec 30 2022, 09:20 PM
V-8 madness
I reinstalled the engine after a rebuild and for some reason that I can't figure out the clutch seems to go out of adjustment when the car warms up.
I park it and let it cool, the clutch works just fine. Pedal play and everything is normal until it warms up again. Seems to be a bit more play but when warm I can't get first or reverse with grinding. Starting in gear with the clutch in, the car still moves.
How can this be?
bdstone914
post Dec 31 2022, 09:38 AM
bdstone914
Did you connect the ground strap from thr trans to body? If not the clutch cable acts as a ground for the engine.
Also check for clutch tube attachment in the tunnel. Remove the shifter bolts and push the shifter to the passenger side. Depress the clutch and see if the tube moves.
Bruce Hinds
post Dec 31 2022, 10:13 AM
V-8 madness
QUOTE(bdstone914 @ Dec 31 2022, 07:38 AM) *
The ground strap is in place and the tube is secure. It had broken loose many years ago and I made a firewall fix as well as a fix in the tunnel to secure it. Again, not sure how heat would cause this to change. I also replaced the cable with a new one.
bdstone914
post Dec 31 2022, 10:33 AM
bdstone914
QUOTE(Bruce Hinds @ Dec 31 2022, 10:13 AM) *
What brand cable did you use? I have heard of problems with Terry cables? Was it wirking with the old cable? Still have it?
Bruce Hinds
post Dec 31 2022, 11:29 AM
V-8 madness
QUOTE(bdstone914 @ Dec 31 2022, 08:33 AM) *
Yes, replace it with the GEMO cable from 914 rubber. But a few hours after driving it, it works fine. I'm sure if it stretched, it wouldn't un-stretch - right?
Bruce Hinds   Clutch Problem   Dec 30 2022, 09:20 PM
914Sixer   Did you replace the clutch fork pivot bushing and ...   Dec 31 2022, 09:08 AM
Bruce Hinds   Did you replace the clutch fork pivot bushing and...   Dec 31 2022, 10:08 AM
bdstone914   Did you connect the ground strap from thr trans to...   Dec 31 2022, 09:38 AM
Bruce Hinds   Did you connect the ground strap from thr trans t...   Dec 31 2022, 10:13 AM
bdstone914   Did you connect the ground strap from thr trans ...   Dec 31 2022, 10:33 AM
Bruce Hinds   [quote name='Bruce Hinds' post='3048368' date='De...   Dec 31 2022, 11:29 AM
914Sixer   Bushing tends to crumble under heat. I do not kno...   Dec 31 2022, 10:33 AM
Bruce Hinds   Bushing tends to crumble under heat. I do not kn...   Dec 31 2022, 11:27 AM
Superhawk996   Bushing tends to crumble under heat. I do not k...   Dec 31 2022, 12:30 PM
Bruce Hinds   [quote name='Bruce Hinds' post='3048382' date='De...   Dec 31 2022, 12:50 PM
Superhawk996   It was perfect before the engine rebuild, BUT ev...   Dec 31 2022, 01:04 PM
Bruce Hinds   It was perfect before the engine rebuild, BUT e...   Dec 31 2022, 01:31 PM
clarkcou   Thanks for the conversation Peter - actually went ...   Jan 2 2023, 01:11 AM
mgphoto   Could be loose motor mounts, it’s not the warm u...   Dec 31 2022, 07:39 PM
izaporsche   I reinstalled the engine after a rebuild and for ...   Jan 2 2023, 07:51 AM
Bruce Hinds   I reinstalled the engine after a rebuild and for...   Jan 2 2023, 10:43 AM
izaporsche   [quote name='izaporsche' post='3048765' date='Jan...   Jan 2 2023, 07:20 PM
Bruce Hinds   [quote name='izaporsche' post='3048765' date='Ja...   Jan 2 2023, 08:06 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 11:37 PM
