> Clutch Problem, Adjustment Changes
Bruce Hinds
post Dec 30 2022, 09:20 PM
V-8 madness
I reinstalled the engine after a rebuild and for some reason that I can't figure out the clutch seems to go out of adjustment when the car warms up.
I park it and let it cool, the clutch works just fine. Pedal play and everything is normal until it warms up again. Seems to be a bit more play but when warm I can't get first or reverse with grinding. Starting in gear with the clutch in, the car still moves.
How can this be?
mgphoto
post Dec 31 2022, 07:39 PM
"If there is a mistake it will find me"
Could be loose motor mounts, it’s not the warm up, the engine and transmission move backwards when going up hill shortening the cable and down hill lengthening it, place a jack under the motor/ transmission and put upward pressure on the assembly, check the torque of mounting bolts.
Bruce Hinds   Clutch Problem   Dec 30 2022, 09:20 PM
914Sixer   Did you replace the clutch fork pivot bushing and ...   Dec 31 2022, 09:08 AM
Bruce Hinds   Did you replace the clutch fork pivot bushing and...   Dec 31 2022, 10:08 AM
bdstone914   Did you connect the ground strap from thr trans to...   Dec 31 2022, 09:38 AM
Bruce Hinds   Did you connect the ground strap from thr trans t...   Dec 31 2022, 10:13 AM
bdstone914   Did you connect the ground strap from thr trans ...   Dec 31 2022, 10:33 AM
Bruce Hinds   [quote name='Bruce Hinds' post='3048368' date='De...   Dec 31 2022, 11:29 AM
914Sixer   Bushing tends to crumble under heat. I do not kno...   Dec 31 2022, 10:33 AM
Bruce Hinds   Bushing tends to crumble under heat. I do not kn...   Dec 31 2022, 11:27 AM
Superhawk996   Bushing tends to crumble under heat. I do not k...   Dec 31 2022, 12:30 PM
Bruce Hinds   [quote name='Bruce Hinds' post='3048382' date='De...   Dec 31 2022, 12:50 PM
Superhawk996   It was perfect before the engine rebuild, BUT ev...   Dec 31 2022, 01:04 PM
Bruce Hinds   It was perfect before the engine rebuild, BUT e...   Dec 31 2022, 01:31 PM
clarkcou   Thanks for the conversation Peter - actually went ...   Jan 2 2023, 01:11 AM
mgphoto   Could be loose motor mounts, it’s not the warm u...   Dec 31 2022, 07:39 PM
izaporsche   I reinstalled the engine after a rebuild and for ...   Jan 2 2023, 07:51 AM
Bruce Hinds   I reinstalled the engine after a rebuild and for...   Jan 2 2023, 10:43 AM
izaporsche   [quote name='izaporsche' post='3048765' date='Jan...   Jan 2 2023, 07:20 PM
Bruce Hinds   [quote name='izaporsche' post='3048765' date='Ja...   Jan 2 2023, 08:06 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 11:52 PM
