> Transmission to engine mating questions
roundtwo
post Dec 30 2022, 12:51 AM
Well...I'm finally at the point of ALMOST installing the engine after a rebuild and an endless series of "while the engines out, I really want to..."
I purchased the nearly "finished' car about six months ago only to find the fresh engine was wrecked and needed a complete tear down. This started the journey to the unknown. Thanks to Bruce Abbott in North Carolina I have a fresh engine and renewed hope. I can't say enough good things about Bruce. A remarkable guy with incredible 911 knowledge. The 1976 3.0 euro Carrera engine is back to its glory.
Meanwhile I stripped the majority of the engine bay to metal. Lots of sanding, epoxy primer and learned to spray single stage acrylic enamel. A bit of welding here and there to clean things up, pertronix wiring/ new sub harness for the engine. Restored the engine shroud (15 hours alone), sorting out the fuel system and on and on...
Transmission rebuilt by Dr. Evil. Now I'm ready to mate the trans to the engine.
A couple of questions:
1. Has a fresh release (throwout) bearing and insulating blocks. Do I need to grease/ pack it at all? If so, what type of grease?
2. Do I grease the main spline that slips into the flywheel? Grease type if so? Conservative amounts of course as to not contaminate the clutch.
3. What else should I consider for the day of the mating? Clutch is all aligned.
thanks in advance...
Attached Image Attached ImageAttached ImageAttached Image
mlindner
post Jan 1 2023, 07:28 AM
First, very nice build. Can't wait to see it all come together. Second, I would add the tangerine shift product, really improves the quality of the shifts. MarkAttached Image
- Lo-Fi Version Time is now: 26th December 2024 - 06:56 PM
