> Clutch Problem, Adjustment Changes
Bruce Hinds
post Dec 30 2022, 09:20 PM
V-8 madness
I reinstalled the engine after a rebuild and for some reason that I can't figure out the clutch seems to go out of adjustment when the car warms up.
I park it and let it cool, the clutch works just fine. Pedal play and everything is normal until it warms up again. Seems to be a bit more play but when warm I can't get first or reverse with grinding. Starting in gear with the clutch in, the car still moves.
How can this be?
izaporsche
post Jan 2 2023, 07:51 AM
QUOTE(Bruce Hinds @ Dec 30 2022, 10:20 PM) *
How can this be?
Hi Bruce,
I am new to this forum, but felt compelled to add my two cents, it’s your pilot bearing. I went through the same thing , replacing clutch cables and clutch disc/pressure plate, making adjustments after every short drive because it became to difficult to shift into gear and nothing seem to help until I finally replaced my pilot bearing problem solved. Rule of thumb is to always replace you pilot bearing whenever you replace your clutch. My Symptoms were exactly like yours. To all of 914 owners out there happy new year, I’ve been on this sight roaming for a long time...great place to read and learn about this funny lookin but beautiful car that I have loved most of my adult life.
Tony
Bruce Hinds
post Jan 2 2023, 10:43 AM
V-8 madness
QUOTE(izaporsche @ Jan 2 2023, 05:51 AM) *
How can this be?
Hi Bruce,
Tony
Hi Tony, welcome to the group. I used to be a lot more active, something happened a few years back where we no longer receive emails when a post is responded to . . . so checking back to get answers is necessary. But I miss a lot of conversations now.
I had heard about the pilot bearing from another source but discounted the idea since I did put a new one in and made sure it was lubed. Perhaps I didn't get the pilot all the way in . . . I was hoping to find an easier solution than going back in there.
izaporsche
post Jan 2 2023, 07:20 PM
QUOTE(Bruce Hinds @ Jan 2 2023, 11:43 AM) *
How can this be?
Hi Bruce,
Tony
Hi Bruce, I replaced my clutch twice thinking that the pressure plate was faulty and the clutch cable once thinking that was the problem, but never thought of replacing the pilot bearing because it felt fine spinning and not binding and was well greased, I think what was happening was the temp going up due to friction causing the bearings to siege up and make it hard to put the car into gear, finally decided to replace the pilot bearing and all is good...after removing the transaxle a couple of times it’s a breeze, approximately 1hr each time..
Bruce Hinds   Clutch Problem   Dec 30 2022, 09:20 PM
914Sixer   Did you replace the clutch fork pivot bushing and ...   Dec 31 2022, 09:08 AM
Bruce Hinds   Did you replace the clutch fork pivot bushing and...   Dec 31 2022, 10:08 AM
bdstone914   Did you connect the ground strap from thr trans to...   Dec 31 2022, 09:38 AM
Bruce Hinds   Did you connect the ground strap from thr trans t...   Dec 31 2022, 10:13 AM
bdstone914   Did you connect the ground strap from thr trans ...   Dec 31 2022, 10:33 AM
Bruce Hinds   [quote name='Bruce Hinds' post='3048368' date='De...   Dec 31 2022, 11:29 AM
914Sixer   Bushing tends to crumble under heat. I do not kno...   Dec 31 2022, 10:33 AM
Bruce Hinds   Bushing tends to crumble under heat. I do not kn...   Dec 31 2022, 11:27 AM
Superhawk996   Bushing tends to crumble under heat. I do not k...   Dec 31 2022, 12:30 PM
Bruce Hinds   [quote name='Bruce Hinds' post='3048382' date='De...   Dec 31 2022, 12:50 PM
Superhawk996   It was perfect before the engine rebuild, BUT ev...   Dec 31 2022, 01:04 PM
Bruce Hinds   It was perfect before the engine rebuild, BUT e...   Dec 31 2022, 01:31 PM
clarkcou   Thanks for the conversation Peter - actually went ...   Jan 2 2023, 01:11 AM
mgphoto   Could be loose motor mounts, it’s not the warm u...   Dec 31 2022, 07:39 PM
izaporsche   I reinstalled the engine after a rebuild and for ...   Jan 2 2023, 07:51 AM
Bruce Hinds   I reinstalled the engine after a rebuild and for...   Jan 2 2023, 10:43 AM
izaporsche   [quote name='izaporsche' post='3048765' date='Jan...   Jan 2 2023, 07:20 PM
Bruce Hinds   [quote name='izaporsche' post='3048765' date='Ja...   Jan 2 2023, 08:06 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 11:51 PM
