> 914 Windshield inside OEM Glass Sticker logo?, Anyone making these OEM Windshield Mfg. Stickers
TJB/914
post Jan 5 2023, 02:10 PM
Mid-Engn.
Looking for help if anyone makes these OEM Windshield Sticker's?
Are they different for every model year?
Many years ago while restoring my 914 I used a solvent to clean up the windshield glass & destroyed the letters. I would like one for my OEM original windshield (IMG:style_emoticons/default/pray.gif)
This is off as recent 1976 in a local shop for repairs in this photo.
Tom Michigan
wonkipop
post Jan 7 2023, 04:09 PM
@JeffBowlsby
re tough v tempered. down here we refer to it as toughened glass.
same thing. heat treated for strength.
you are right about the side glazing. if it has got the F. might have to look further into that. the jag website i linked to above lists all the letters used. states F is for float glass.
that info might be wrong. the glass in my car is Delodur1 in the side windows and rear window so i had not picked up on that F being there. further investigation required. (IMG:style_emoticons/default/biggrin.gif)
the windscreen from the car on BAT is a USA rated windscreen.
nothing mysterious there. its got the AS1 rating marked on it.
its also laminated as it should be. see at the top. of the marking
the plate glass descriptor is interesting.
there will be an explanation for that.
could be as simple as the germans changed the term but where referring to the same thing. ie sheet glass/plate glass/float glass. you can get yourself into tricky territory with the old plate glass versus float glass discussion. anyway its a lam screen.
its very similar to the 73 screen i posted on first page of this thread.
similar but not exactly the same.
need more info/data.
the PET i referred to showed a distinct windscreen for both the 914/6 and the 914 2.0 together rather than just the 6. still - as you say, what was that about. yet it has the same part number as the one for standard 4s. dunno.
more data needed.
re M numbers. they would be different for each manufacturer.
but they might be describing the same thing. ie same construction.
anyways, i'm only going to poke my head into kinonglas. as far as i can tell that is the one that the factory was installing. (IMG:style_emoticons/default/biggrin.gif)
i am not sure about the tempered over tempered for a windscreen in the USA.
or as we would say, toughened over toughened.
i know a lot about glass in architectural applications.
normally we cannot get laminated toughened. its laminated float.
we can only get toughened as single sheet.
now that may be a limitation of architectural glass and codes as they relate to regulation rather than a manufacturing limitation.
further research required.
however, that screen you have posted from BAT is USA so its a moot point.
AS1 on the DOT and M line means its a USA approved screen or USA standard screen.
herz means heart.
a couple of ways you could see that wavy line.
a sine wave. hertz.
a heartbeat herz.
who knows exactly why the germans chose that symbol.
they just did.
the French as i found out use the word AGREE instead of a symbol. which means APPROVED.
some more work to do.
the F thing is interesting. you may be right.
have to investigate further.
i'll look into DELODUR and see what that is about.
i guess its a bit like the ECA/B research.
you have to acquire enough examples to get to the bottom of it.
TJB/914   914 Windshield inside OEM Glass Sticker logo?   Jan 5 2023, 02:10 PM
SteveL   Pretty sure That is a stamp, not a sticker   Jan 5 2023, 03:19 PM
TJB/914   Pretty sure That is a stamp, not a sticker Stev...   Jan 5 2023, 03:32 PM
JeffBowlsby   ^^^agree. Not a sticker.   Jan 5 2023, 03:24 PM
rick 918-S   I thought OEM was sigla.and it is etched in the gl...   Jan 5 2023, 03:28 PM
TJB/914   I thought OEM was sigla.and it is etched in the g...   Jan 5 2023, 03:36 PM
wonkipop   I thought OEM was sigla.and it is etched in the ...   Jan 5 2023, 06:11 PM
TJB/914   I thought OEM was sigla.and it is etched in the g...   Jan 5 2023, 03:38 PM
vitamin914   I was a tooling engineer at PPG in the late 80s. ...   Jan 5 2023, 04:06 PM
JeffBowlsby   Interesting. Can you decipher the date or date co...   Jan 5 2023, 04:41 PM
wonkipop   Interesting. Can you decipher the date or date c...   Jan 5 2023, 07:10 PM
vitamin914   Interesting. Can you decipher the date or date c...   Jan 6 2023, 08:02 AM
wonkipop   ok - did some googling as i am always curious. ki...   Jan 5 2023, 06:53 PM
Mikey914   It's like a tempering bug. It's a frit sta...   Jan 5 2023, 07:11 PM
TJB/914   Interesting 914 factory information. I am cleanin...   Jan 5 2023, 07:18 PM
wonkipop   Interesting 914 factory information. I am cleani...   Jan 5 2023, 07:33 PM
JeffBowlsby   The ziggy-zaggy line is the Sigla logo.   Jan 5 2023, 08:30 PM
wonkipop   The ziggy-zaggy line is the Sigla logo. just to...   Jan 5 2023, 09:04 PM
wonkipop   @JeffBowlsby . i have a feeling (hunch) but could...   Jan 5 2023, 09:21 PM
wonkipop   here is how you tell who made the windscreen. its ...   Jan 5 2023, 11:48 PM
vitamin914   the weird logo in the sudglas screen is not a...   Jan 6 2023, 06:20 AM
wonkipop   amusing bonus digging around on kraut glass. its r...   Jan 6 2023, 12:49 AM
scott_in_nh   While my originality concerns don't extend to ...   Jan 6 2023, 08:38 AM
vitamin914   While my originality concerns don't extend to...   Jan 6 2023, 11:16 AM
TJB/914   :woohoo: This really opened up the 914 brain tr...   Jan 6 2023, 11:06 AM
scott_in_nh   Thanks! It makes sense that the year is 1990 a...   Jan 6 2023, 11:50 AM
JeffBowlsby   What I am seeing in many of the 914 images posted ...   Jan 6 2023, 12:03 PM
wonkipop   What I am seeing in many of the 914 images posted...   Jan 6 2023, 08:04 PM
wonkipop   wow @vitamin914 interesting info download. tha...   Jan 6 2023, 07:44 PM
JeffBowlsby   Found this with a google search. I wonder what AB...   Jan 6 2023, 09:08 PM
wonkipop   Found this with a google search. I wonder what A...   Jan 6 2023, 10:29 PM
JeffBowlsby   I wonder if you can a few missing smdescriotions s...   Jan 6 2023, 11:41 PM
wonkipop   I wonder if you can a few missing smdescriotions ...   Jan 6 2023, 11:55 PM
JeffBowlsby   I don’t recall, but I don’t think so. Maybe u...   Jan 6 2023, 11:02 PM
wonkipop   I don’t recall, but I don’t think so. Maybe ...   Jan 7 2023, 12:16 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 6 2023, 11:16 PM
wonkipop   by the way i think the herz symbol is cute on the ...   Jan 7 2023, 12:03 AM
wonkipop   @JeffBowlsby i got my crack researcher on to it....   Jan 7 2023, 01:11 AM
JeffBowlsby   A couple of things I am curious about: On the sid...   Jan 7 2023, 11:07 AM
wonkipop   @JeffBowlsby re tough v tempered. down here we...   Jan 7 2023, 04:09 PM
wonkipop   @JeffBowlsby i had a look at the car on BAT you ...   Jan 7 2023, 04:33 PM
wonkipop   to explain a little further about the front screen...   Jan 7 2023, 05:41 PM
wonkipop   @JeffBowlsby getting a bit closer on the DELODUR...   Jan 7 2023, 06:49 PM
vitamin914   @wonkipop [b]@[url=http://www.914world.com/bbs2/...   Jan 7 2023, 07:12 PM
wonkipop   thanks for that @vitamin914 your remarks regard...   Jan 7 2023, 07:37 PM
wonkipop   @vitamin914 that is just brilliant about the sun...   Jan 7 2023, 07:52 PM
wonkipop   @JeffBowlsby [b]@[url=http://www.914world.com/bb...   Jan 7 2023, 08:30 PM
wonkipop   @JeffBowlsby ok i just went back into PET on win...   Jan 7 2023, 08:58 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 7 2023, 09:43 PM
wonkipop   @JeffBowlsby one more for you. i was trying to t...   Jan 7 2023, 11:01 PM
wonkipop   alright @JeffBowlsby i dug into heat protected ...   Jan 8 2023, 12:44 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 8 2023, 01:12 AM
vitamin914   Heat absorbing glass has been around for an awfull...   Jan 8 2023, 02:44 PM
wonkipop   Heat absorbing glass has been around for an awful...   Jan 8 2023, 03:19 PM
vitamin914   Heat absorbing glass has been around for an awfu...   Jan 8 2023, 07:09 PM
wonkipop   [quote name='wonkipop' post='3049984' date='Jan 8...   Jan 9 2023, 03:20 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 8 2023, 03:10 PM
StarBear   @wonkipop [b]@[url=http://www.914world.com/bbs2/...   Jan 9 2023, 10:44 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 9 2023, 03:08 PM
StarBear   [quote name='StarBear' post='3050135' date='Jan 9...   Jan 9 2023, 03:52 PM
vitamin914   @StarBear Is this what the trademark looks like ...   Jan 9 2023, 04:12 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 9 2023, 04:36 PM
StarBear   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 9 2023, 04:42 PM
StarBear   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 10 2023, 08:12 AM
wonkipop   @vitamin914 i'm just looking at your certifi...   Jan 9 2023, 04:45 PM
vitamin914   @[url=http://www.914world.com/bbs2/index.php?show...   Jan 9 2023, 08:11 PM
wonkipop   [quote name='wonkipop' post='3050193' date='Jan 9...   Jan 9 2023, 08:19 PM
wonkipop   @StarBear thats great you have your "window...   Jan 9 2023, 04:54 PM
wonkipop   we just need @Van B to pipe in now. :D :D he h...   Jan 9 2023, 05:00 PM
StarBear   Here it is. “tinted windshield”. Side glass no...   Jan 9 2023, 05:03 PM
wonkipop   so this is the late 74 2.0 that was on BAT and ver...   Jan 9 2023, 05:09 PM
JeffBowlsby   Clear glass was standard and the rear glass was al...   Jan 9 2023, 05:23 PM
wonkipop   Clear glass was standard and the rear glass was a...   Jan 9 2023, 05:54 PM
wonkipop   Clear glass was standard and the rear glass was a...   Jan 11 2023, 05:30 PM
davep   Clear glass was standard and the rear glass was a...   Jan 16 2023, 07:26 AM
Van B   Here ya go. Such a shame that I have the crack ov...   Jan 9 2023, 06:10 PM
wonkipop   @Van B :beer2: :beer2: :beer2: :beer2: i t...   Jan 9 2023, 06:12 PM
BR9   What about my rare Mexican front windshield?   Jan 9 2023, 06:19 PM
wonkipop   What about my rare Mexican front windshield? :...   Jan 9 2023, 06:36 PM
wonkipop   @Van B and [b]@[url=http://www.914world.com/bbs2...   Jan 9 2023, 06:44 PM
sb914   :blowup: :deadhorse2: 4 pages ? :poke: Sorry I...   Jan 9 2023, 08:13 PM
wonkipop   :blowup: :deadhorse2: 4 pages ? :poke: Sorry ...   Jan 9 2023, 08:25 PM
vitamin914   :blowup: :deadhorse2: 4 pages ? :poke: Sorry ...   Jan 9 2023, 08:31 PM
dgw   I think this thread is hilarious. I like to read t...   Jan 9 2023, 10:33 PM
wonkipop   I think this thread is hilarious. I like to read ...   Jan 10 2023, 12:09 AM
vitamin914   I think this thread is hilarious. I like to read ...   Jan 10 2023, 07:34 AM
wonkipop   I think this thread is hilarious. I like to read...   Jan 10 2023, 02:49 PM
StarBear   I think this thread is hilarious. I like to read ...   Jan 10 2023, 08:07 AM
L-Jet914   @wonkipop Unfortunately my windshield was replace...   Jan 10 2023, 02:15 PM
wonkipop   some more trivia you don't have to read :beer...   Jan 10 2023, 02:34 PM
Van B   Now does sekurit still make replacement glass? Th...   Jan 10 2023, 06:49 PM
wonkipop   Now does sekurit still make replacement glass? T...   Jan 10 2023, 06:57 PM
wonkipop   a titbit at the end for the front badge conscious....   Jan 10 2023, 06:51 PM
Van B   Wonkipop. That logo is all over porsche parts. I ...   Jan 10 2023, 06:57 PM
wonkipop   Wonkipop. That logo is all over porsche parts. I...   Jan 10 2023, 06:59 PM
JeffBowlsby   How is Kinonglas pronounced (phonetically)? Kai-n...   Jan 10 2023, 08:34 PM
SirAndy   How is Kinonglas pronounced (phonetically)? Kai-...   Jan 10 2023, 08:51 PM
JeffBowlsby   I reviewed that page too the other day and have th...   Jan 11 2023, 05:56 PM
wonkipop   I reviewed that page too the other day and have t...   Jan 11 2023, 06:25 PM
wonkipop   condensed version over in originality section. jus...   Jan 17 2023, 06:23 AM
43 User(s) are reading this topic (43 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 01:48 PM
