nivekdodge |
Member ![]() ![]() Group: Members Posts: 251 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region ![]() ![]() |
Like Bob Krantz, Powerplant in ....Powerplant out.Cha-Cha. I'm waiting for tranny parts and replaced the one pushrod seal that was leaking. The motor still has oil in it. Can i tilt it 10 degrees or so overnight to check for a leak?
Kevin |
nathanxnathan |
Member ![]() ![]() Group: Members Posts: 291 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California ![]() |
The motor will more likely leak when it's hot and running. The oil is thinner at temperature and quite a lot of oil goes from the head to the sump via the pushrod tubes. To check it when it's cold and not running isn't going to show you very much. ...if I am understanding what it is you're asking. With the trouble to remove rockers etc, I would opt to redo all the pushrod tube seals at once.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,214 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
The motor will more likely leak when it's hot and running. The oil is thinner at temperature and quite a lot of oil goes from the head to the sump via the pushrod tubes. To check it when it's cold and not running isn't going to show you very much. ...if I am understanding what it is you're asking. With the trouble to remove rockers etc, I would opt to redo all the pushrod tube seals at once. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:20 AM |
