r_towle |
I have a side shifter that leaks at the console.
I cold drip every hour… I bought the transmission gasket set from pelican There is nothing in the set for the shifter console….nada I removed the console It looks like there is a bushing at the bottom. Does anyone have a clue on part numbers to order to rebuild the shifter console? It’s a 75/76 if that matters. Rich |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Do not use the paper gasket under the console. That is a part for the tail shift only and goes on the side plug which does not use the O ring. Note in the above diagram the missing gasket, because its not used and using it can cause issues. Just change the O ring and seal on the lower shaft and you are good to go.
Lo-Fi Version | Time is now: 24th June 2024 - 07:36 AM |
