Saved From the Car Crusher!, Maybe parts should have been crushed???? |
PlantMan |
Jul 4 2014, 12:13 AM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Hey All,
I saved this car, I am sure, from pending doom as it was sitting in a Coparts yard in the SF Bay area, not to mention it was donated to charity........ I thought it had potential so I scooped it up. My last 914 was a 1.7 (72) and I always wanted the 73-74 2.0l, so here we are. Anyways, you can see from the attached photos she is a little long in the tooth!!! BTW, this car is a true California car and appears to have spent it's entire life in NorCal. Who said Cal cars have little rust??? It also appeared to have a trans change-out around 30k miles, interesting. I have gone through 80% so far, got the car up and running, fixed a majority of the oil leaks, and now getting the brakes sorted out so I can road test it. Interior is in very good shape, minus the carpet, dashboard is a solid A grade for 40 years old and the seats and back pad are still quality as well. I am debating the AC system, which I will remove for now, but it might go back in in the future. The motor starts right-up without any problems and after I get the brakes back on I am going to check for vacuum leaks, it has a high idle but I think maybe the AAR maybe stuck. Debating the next step, starting from the front of the car and possibly working my way to the back, doing the body work. I am trying to gather pieces now for the sheet metal clean-up. Enjoy the photos! I did add it to the VIN database as well. [attachmentid=457 680] [attachmentid=457 688] Attached image(s) |
930cabman |
Jan 23 2023, 03:34 PM
Advanced Member Group: Members Posts: 3,220 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
The longs are double thickness, staggering your lap seams is best, but tricky. Some of the metal is available, but some must be fabricated as you go. All the while make sure the chassis is straight and true. Quite the project, keep the faith and "soon" she will surrender.
Lo-Fi Version | Time is now: 29th June 2024 - 05:17 PM |
