bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,835 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
I have a Shadek pump adapted for Type 4 (which I know some people don't like). The first time I installed the pump cover I did not use a gasket, just case-sealant. For the second time around, should I use a gasket under the cover?
bkrantz |
Let me check my understanding. Optimum gear clearance is .003". I measured my pump gears (relative to the face of the pump) and got mostly .0005 to .001.
The only gasket I have in my stock measures .0045". That would give me clearance of .005 to .006, which might be too much. Are there gaskets only .0025 thick? Attached thumbnail(s) ![]() |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,215 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Let me check my understanding. Optimum gear clearance is .003". I measured my pump gears (relative to the face of the pump) and got mostly .0005 to .001. The only gasket I have in my stock measures .0045". That would give me clearance of .005 to .006, which might be too much. Are there gaskets only .0025 thick? I pulled a new Schadek pump off the shelf and measured the paper gasket to be .003. I am unsure if these can be had directly from Schadek? |
Lo-Fi Version | Time is now: 26th June 2024 - 11:00 AM |
