bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,842 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
I have a Shadek pump adapted for Type 4 (which I know some people don't like). The first time I installed the pump cover I did not use a gasket, just case-sealant. For the second time around, should I use a gasket under the cover?
bkrantz |
With a moderate amount of pressure, I got a thickness of .0025.
If I have gear clearance in the pump, relative to the pump face of around .001, that give me .0035 total clearance with the gasket installed and compressed. I think that should be right. Right? Attached thumbnail(s) ![]() |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,220 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
With a moderate amount of pressure, I got a thickness of .0025. If I have gear clearance in the pump, relative to the pump face of around .001, that give me .0035 total clearance with the gasket installed and compressed. I think that should be right. Right? I would say you are right on the money. get it together and hopefully that was your leakage issue. |
Lo-Fi Version | Time is now: 29th June 2024 - 04:42 AM |
