One more oil pump question: gasket or not |
bkrantz |
Jan 21 2023, 08:12 PM
914 Guru Group: Members Posts: 7,835 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have a Shadek pump adapted for Type 4 (which I know some people don't like). The first time I installed the pump cover I did not use a gasket, just case-sealant. For the second time around, should I use a gasket under the cover?
ChrisFoley |
Jan 26 2023, 05:39 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
That gasket looks pretty sturdy, more like ones I use at the back of the pump.
The cover gaskets I use are thinner than paper. CB Performance pumps are Schadek pumps. They sell the gaskets. |
Superhawk996 |
Jan 26 2023, 07:52 AM
914 Guru Group: Members Posts: 5,995 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
That gasket looks pretty sturdy, more like ones I use at the back of the pump. The cover gaskets I use are thinner than paper. CB Performance pumps are Schadek pumps. They sell the gaskets. I agree on the visual. The old VW gaskets were brown and almost translucent when they had oil on them, they were so thin. From the holes in the gasket, we can tell your gasket is intended for use on the cover side of the pump. Based on the measurements I think you’ll be fine. So let’s assume the original VW gaskets were 1/2 as thick - let’s call it 0.002” for argument sake. Bentley manual allowed 0.004” end play without a gasket. Now combine that with a 0.002” gasket and you have a total of 0.006”. In your case, the oil pump end play is way smaller than spec at 0.001”. Combine that with a 0.003” gasket and you’re still less than what was spec back in the day without a gasket. Looking around on the web, it’s the usual BS. No one actually lists how thick their gaskets are (IMG:style_emoticons/default/headbang.gif). Sometimes I’m really frustrated with the aftermarket and their propensity for marketing hype, claims made without data, and failure to publish specs. That leaves the option of ordering from a few sources and sorting to find the thinnest. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 11:06 AM |
