Rear trunk latch stuck, how do you get in? |
BR9 |
Jan 28 2023, 12:32 PM
Newbie Group: Members Posts: 24 Joined: 19-February 22 From: FLORIDA Member No.: 26,347 Region Association: South East States |
I can put the key in and it turns to about 1 degree away from where the button should pop out but it stops. I sprayed some PB blaster, and other than making it turn really easily in the zone it could already move in, it didn't help that last little bit to make it open.
I tried slightly pressing on the lid right at the lock but it doesn't help. It's been sitting for 30 years and hasn't been opened in that amount of time. I've owned it since '84 so I know its history. Is there some way to use an o-ring pick or such to get at the mechanism to free it? |
ClayPerrine |
Jan 28 2023, 12:49 PM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Open the engine compartment
Push the cups for the top latches into the trunk from the engine compartment. Put a bright flashlight in one of the cup holes. Get a 10MM wobble socket and put it on a long extension. Feed it into the unused cup hole. Keep adding extensions until you can unbolt the trunk catch at the back of the trunk. That's how to do it without damaging something. Hope that helps. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:42 AM |
