Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
If all goes as planned, I should be swapping out my stock old distributor for a brand new Mallory distributor running a CDI box in the next few weeks. In the past this was not possible since the trigger points for the FI are located in the base of the D-Jet distributor....on my work bench, I have come up with a bolt-on solution that should cost no more than about $35 that will fit inside of a Mallory Unilite distributor.....I do not have an MSD distributor, but I'd imagine the same type of unit could be installed fairly easily.
just thought I'd see if I am the only crazy person wanting to upgrade/change their ignition? (legal mod for local Bp cars, you must keep the stock FI, but no limit on the ignition) |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
This has been discussed. It's not at all straightforward, because of the way the MPS works and interacts with the ECU. Brad Anders gave me the poop, and it's pretty clear that replacing the MPS requires nearly a complete MS-class ECU. At that point, you may as well just replace the D-Jet ECU with an MS ECU and save yourself a lot of trouble. Mike's little solution here, though, is a pretty nice step forward for anyone wanting to use a Mallory with D-Jet. |
Lo-Fi Version | Time is now: 30th June 2024 - 01:04 PM |
