fuel pump relocation under steering rack pictures? |
Geezer914 |
Feb 4 2023, 08:57 AM
Geezer914 Group: Members Posts: 1,789 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
rhodyguy |
Feb 5 2023, 01:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,193 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
To even look at what might be the problem, even in your garage, you jack up the car, get under it, remove the pan retaining hardware, set the pan aside, investigate the problem, then (if you’re lucky) perform the repair, put everything back together and be on your way. This would be a major undertaking with a dead car south of a place like Drain OR. Best solution for moving the pump forward is sourcing a OEM cover/pump holder and mimicking the factory setup. Figure out how you intend to power the pump first. Planning on carrying a floor jack rather than trusting the factory jack? Not on level ground? You roll the dice going under the car. Maybe become a statistic.
Lo-Fi Version | Time is now: 21st December 2024 - 08:35 AM |
