What to do if you lost your keys?, Another key question |
Type 47 |
Jan 31 2023, 08:33 PM
Senior Member Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
We are getting really close to the finish line on the 75' so getting down to small stuff.
Apparently, the 2 steel keys that came with the car are valet keys that only open the doors and work in the ignition. So, the other 3 locks don't have a key. If I'm to ever have a proper red and black key, is there a way to make a key from the say trunk lock? If you would get a Porsche CoA does it have key codes? |
TheCabinetmaker |
Feb 1 2023, 06:12 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Take the key you have to a local locksmith and have him make a copy from a P05 blank and see if that fits the trunks and glovebox. If no, I can make them work
Type 47 |
Feb 6 2023, 11:39 AM
Take the key you have to a local locksmith and have him make a copy from a P05 blank and see if that fits the trunks and glovebox. If no, I can make them work The local locksmith only could duplicate the steel key. I tried to email you about making some keys but I'm not sure email or PM works for me all the time...could be a user problem. |
GregAmy |
Feb 6 2023, 11:59 AM
Advanced Member Group: Members Posts: 2,314 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
The local locksmith only could duplicate the steel key. Just to ensure you understand...the cut is exactly the same for the valet and trunks/glovebox keys; the only difference is the blank used. Curtis is the man on this, he replied above to ask for a P05 blank. Can the local guy get that blank? If so, have him cut that blank to match the valet keys you have. - GA |
Type 47 |
Feb 6 2023, 01:27 PM
The local locksmith only could duplicate the steel key. Just to ensure you understand...the cut is exactly the same for the valet and trunks/glovebox keys; the only difference is the blank used. Curtis is the man on this, he replied above to ask for a P05 blank. Can the local guy get that blank? If so, have him cut that blank to match the valet keys you have. - GA Thanks for the clarification, I get it (I think) now. So the P05 blank is a Porsche blank? Like pictured below? I had a knock off black blank laying around, so that is what the locksmith keyed. It still only turns in the door/ignition. |
GregAmy |
Feb 6 2023, 03:54 PM
So the P05 blank is a Porsche blank? Like pictured below? Correct. The middle key is for the doors and ignition; note that it does not have that additional longitudinal slot? That's what activates the "valet" wafer. But the key code is (supposed to be) exactly the same. QUOTE I had a knock off black blank laying around, so that is what the locksmith keyed. It still only turns in the door/ignition. OK, so that indicates that someone may have replaced your ignition tumbler and it no longer matches the doors and trunk/box. In that case, you're going to need to get the ignition barrel adjusted for that key you have. Curtis is the man for that @TheCabinetMaker GA EDIT: Follow up: in comparing those keys, it looks like the black middle one is not EXACTLY the same? Maybe try jiggling around the key in the ignition tumbler as you lightly turn it? Otherwise, contact Curt. EDIT 2: and Curt can cut a key based on that photo above...and so can anyone else with the skills. And this forum gets sucked up by spiders for addition to the Internet Archive (for forever). Might want to remove that attachment and just send it direct to Curt. |
Type 47 |
Feb 6 2023, 04:59 PM
It does work in the ignition and the doors.
Lo-Fi Version | Time is now: 26th June 2024 - 09:22 AM |
