Spring (sort of) 914-6 conversion packages |
mb911 |
Feb 11 2023, 08:48 AM
914 Guru Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am offering a spring sale on oil tank, filler neck, filter console, engine sheet metal. This makes the conversions much more budget minded. $1200 for everything shipped. There maybe delays in shipping depending on what is inventory at the time of order.
Engine sheet metal is much improved over the original sets but I encourage everyone to fit and trim as needed prior to painting. Now to the oil tanks. These are far superior to the oem tanks as they are both vertically and horizontally baffled to eliminate air in the oil and to help with sloshing in the tank. They are made of .090 5052 aluminum and are all pressure tested prior to shipping. No rusting takes place with these tanks and allow for either metric or AN fittings to be used. Filter consoles are anodized aluminum and use the oc54 oil filter like the 74-89 911 and eliminates the need for bypass that gets gummed up on the factory consoles |
SirAndy |
Feb 11 2023, 10:53 AM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
@mb911
Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) |
sixnotfour |
Feb 11 2023, 11:00 AM
914 Wizard Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/beerchug.gif) great improvement...so many 911 owners rely on this feature.. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:25 AM |
