> Not getting power from key to starter, can jump power and start engine but not from key
Type 47
post Feb 15 2023, 05:21 PM
We've been trying to figure this out for a couple of days. The car was converted to carbs by the PO and was running and starting fine before I took it apart.
Now, nothing happens when key is in start position but we can start if we touch pole 2 (powering fuel pump) and 4 together from open FI harness plug receptacle.
pole 1 being drivers front, 2 passenger front, 3 drivers rear, 4 passenger rear.
one other difference is that now using a Carter fuel pump versus the Faucet that was originally on the car.
Type 47   Not getting power from key to starter   Feb 15 2023, 05:21 PM
Superhawk996   Here is the relay board schematic When key is ...   Feb 15 2023, 05:47 PM
Type 47   Here is the relay board schematic When key is...   Feb 15 2023, 07:02 PM
Superhawk996   I have a feeling it's something with the sea...   Feb 15 2023, 07:53 PM
bdstone914   @Superhawk996 I have seen several relay boards ...   Feb 15 2023, 08:05 PM
rhodyguy   Where does that red wire connect? Check out the â€...   Feb 15 2023, 06:21 PM
Type 47   Where does that red wire connect? Check out the â...   Feb 15 2023, 07:06 PM
bdstone914   @Type 47 You probably have a bad interlock relay...   Feb 15 2023, 08:12 PM
davep   If you have the seatbelt interlock hooked up, and ...   Feb 15 2023, 09:26 PM
Type 47   If you have the seatbelt interlock hooked up, and...   Feb 16 2023, 04:36 PM
euro911   [quote name='davep' post='3058414' date='Feb 15 20...   Feb 16 2023, 09:34 PM
Type 47   You might want to increase the size of the red j...   Feb 16 2023, 09:40 PM
davep   Great result. I assume this is 4752900696 since 19...   Feb 16 2023, 06:43 PM
Type 47   Great result. I assume this is 4752900696 since 1...   Feb 16 2023, 09:25 PM
rhodyguy   There is a very small gauge wire from the interloc...   Feb 16 2023, 09:45 PM
ClayPerrine   I suggest that you remove the yellow and yellow/re...   Feb 17 2023, 07:59 AM
davep   This type of connector from a 1976 car is the be...   Feb 17 2023, 08:34 AM
- Lo-Fi Version Time is now: 15th January 2025 - 03:20 AM
