Pedal floor boards, Is there a way??? |
nivekdodge |
Feb 15 2023, 08:11 PM
Member Group: Members Posts: 285 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
Little things are annoying me. Is there a process to get the floor board back aroung the pedals without disconnecting the accelerator from the cable?
Kevin |
914 RZ-1 |
Feb 15 2023, 09:17 PM
Porsche Padawan Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
It's not easy, but it can be done. It's like a puzzle that only goes together one way. I can't remember exactly how I did it, but you twist and turn and it will go over the pedals. It's hard to explain! Patience!
Garland |
Feb 15 2023, 11:56 PM
Restoration Fanatic Group: Members Posts: 1,400 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
It's not easy, but it can be done. It's like a puzzle that only goes together one way. I can't remember exactly how I did it, but you twist and turn and it will go over the pedals. It's hard to explain! Patience! Pop the Excelerator rod off the back of the excelerator pedal. Then the board will go in, with some movement of the clutch and brake pedal’s. |
nivekdodge |
Feb 16 2023, 12:31 PM
It's not easy, but it can be done. It's like a puzzle that only goes together one way. I can't remember exactly how I did it, but you twist and turn and it will go over the pedals. It's hard to explain! Patience! Pop the Excelerator rod off the back of the excelerator pedal. Then the board will go in, with some movement of the clutch and brake pedal’s. But then to get the accelerator rod back in I have to remove the floorboard (IMG:style_emoticons/default/sawzall-smiley.gif) |
Garland |
Feb 16 2023, 01:02 PM
It's not easy, but it can be done. It's like a puzzle that only goes together one way. I can't remember exactly how I did it, but you twist and turn and it will go over the pedals. It's hard to explain! Patience! Pop the Excelerator rod off the back of the excelerator pedal. Then the board will go in, with some movement of the clutch and brake pedal’s. But then to get the accelerator rod back in I have to remove the floorboard (IMG:style_emoticons/default/sawzall-smiley.gif) Only remove from back of pedal socket. Just pull, the pedal towards you. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th January 2025 - 04:31 AM |
