timing and time again, timing question |
doobie123 |
Feb 16 2023, 06:10 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi ya'll
let me just say up front, i'm pretty new to this so if my questions seem obvious, sorry so i'm working on a 75 with a 2.0 and 5 spd. i have the engine and trans out to do the clutch and cleanup the bay etc. before i put everything back i want to set the valves. i brought #1 piston to TDC. i did this with the use of a scope and since the engine is out, i can see the piston. when i did this, i took the cap off the distributor, and to my untrained eye, it looks like it's 180 degrees out but, i'm not sure because, well, i'm green. so my question is, is it 180 out? if so, can i just pull the distributor and rotate it where it need to be? if so, am i moving the line on the case to match the rotor or the rotor to match the line? i guess i should also say, i bought a non running car. i had it running before pulling the drive train but just for a bit and only drove it up and down the block so i really don't know the history. thanks for any help Attached thumbnail(s) |
914043 |
Feb 16 2023, 06:16 PM
Member Group: Members Posts: 94 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California |
If you had it running before it sounds like you've got the piston on the exhaust stroke not compression. :)It also looks like you have a timing mark 180 around on the dist. body
Lo-Fi Version | Time is now: 15th January 2025 - 04:33 AM |
