> Not getting power from key to starter, can jump power and start engine but not from key
Type 47
post Feb 15 2023, 05:21 PM
We've been trying to figure this out for a couple of days. The car was converted to carbs by the PO and was running and starting fine before I took it apart.
Now, nothing happens when key is in start position but we can start if we touch pole 2 (powering fuel pump) and 4 together from open FI harness plug receptacle.
pole 1 being drivers front, 2 passenger front, 3 drivers rear, 4 passenger rear.
one other difference is that now using a Carter fuel pump versus the Faucet that was originally on the car.
ClayPerrine
post Feb 17 2023, 07:59 AM
I suggest that you remove the yellow and yellow/red wires from the block and splice them together. Then you don't have to worry about it in the future.
Type 47   Not getting power from key to starter   Feb 15 2023, 05:21 PM
Superhawk996   Here is the relay board schematic When key is ...   Feb 15 2023, 05:47 PM
Type 47   Here is the relay board schematic When key is...   Feb 15 2023, 07:02 PM
Superhawk996   I have a feeling it's something with the sea...   Feb 15 2023, 07:53 PM
bdstone914   @Superhawk996 I have seen several relay boards ...   Feb 15 2023, 08:05 PM
rhodyguy   Where does that red wire connect? Check out the â€...   Feb 15 2023, 06:21 PM
Type 47   Where does that red wire connect? Check out the â...   Feb 15 2023, 07:06 PM
bdstone914   @Type 47 You probably have a bad interlock relay...   Feb 15 2023, 08:12 PM
davep   If you have the seatbelt interlock hooked up, and ...   Feb 15 2023, 09:26 PM
Type 47   If you have the seatbelt interlock hooked up, and...   Feb 16 2023, 04:36 PM
euro911   [quote name='davep' post='3058414' date='Feb 15 20...   Feb 16 2023, 09:34 PM
Type 47   You might want to increase the size of the red j...   Feb 16 2023, 09:40 PM
davep   Great result. I assume this is 4752900696 since 19...   Feb 16 2023, 06:43 PM
Type 47   Great result. I assume this is 4752900696 since 1...   Feb 16 2023, 09:25 PM
rhodyguy   There is a very small gauge wire from the interloc...   Feb 16 2023, 09:45 PM
ClayPerrine   I suggest that you remove the yellow and yellow/re...   Feb 17 2023, 07:59 AM
davep   This type of connector from a 1976 car is the be...   Feb 17 2023, 08:34 AM
- Lo-Fi Version Time is now: 15th January 2025 - 03:11 AM
