malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Have only run maybe 4 gallons of gas thru a new rebuiltengine. Ran on the bench and recently installed. My cooling fan came loose.
Woodruff key is damaged along with the slot in the crank where it sits. Hub too. Is there a way to suitably repair the crank without total engine removal and teardown ? |
malcolm2 |
I can't imagine that this will be JB Weld kinda fix....
I am not sure about the HOW. The O-ring from a rebuild kit was very flat, squished, when I removed it. It is also gouged. Don't know if the gouging came after tho. As I torqued nuts and bolts on this engine, I marked the head with a paint pen. This bolt had the mark on it. Some how came loose. ![]() |
Lo-Fi Version | Time is now: 30th June 2024 - 10:34 AM |
