malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Have only run maybe 4 gallons of gas thru a new rebuiltengine. Ran on the bench and recently installed. My cooling fan came loose.
Woodruff key is damaged along with the slot in the crank where it sits. Hub too. Is there a way to suitably repair the crank without total engine removal and teardown ? |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,286 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Just trial fit a new woodruff key it the slot to see if it fits tight, if so, no crank mods needed. I bent one also cause the flywheel wasn't torqued enough during cam break-in
Put in new key and all was fine |
Lo-Fi Version | Time is now: 30th June 2024 - 10:22 AM |
