Cooling fan woodruff key, Crank is damaged |
malcolm2 |
Feb 25 2023, 06:44 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Have only run maybe 4 gallons of gas thru a new rebuiltengine. Ran on the bench and recently installed. My cooling fan came loose.
Woodruff key is damaged along with the slot in the crank where it sits. Hub too. Is there a way to suitably repair the crank without total engine removal and teardown ? |
malcolm2 |
Feb 25 2023, 08:27 AM
Yes, the pulley was loose. ALT belt vibrating like crazy, vibrating other tin around it. I heard it first.
The close up looks like the key slot is really raised up, but, to the touch, it is not. In this case there is a hub that is what is attached here. The key did some damage in the slot of the hub. I do have a 2nd, undamaged hub. Fan is fine. What is the groups thoughts on the o-ring source? I found that size is 28 x 3. I can get a large assortment of metric sizes from Amazon for like $7 vs AA has 1 for $5.25 then $7 shipping. Pelican is about the same, but they will take 9 days to find the part and pack it up.... crazy. |
Lo-Fi Version | Time is now: 30th June 2024 - 10:42 AM |
