> Flappy, Bouncy, Wacky Tachometer?!, Tachometer bounces back and forth while driving at constant speed
vjb206
post Feb 25 2023, 08:59 AM
Hi folks! First time/long time for me here in the Garage. I just purchased a '74 1.8 in Ohio and it died on me in PA on the way home to NJ. Right before it died I noticed this bouncy/flappy tach thing happening.
(IMG:http://www.914world.com/bbs2/uploads_offsite/media.giphy.com-23760-1677337178.1.gif)
As you can see my speed is constant, my throttle inputs steady – just cruising. However the tach is going nuts.
When the car died (in a rest area off I-80 in PA) it would turn over but not start. We ran some rudimentary diagnostics and remediation measures:
- Heard clicking/popping noise coming from driver's side of engine bay at speed, this was accompanied by the flappy tach phenomenon
- Generator light came on at some point while driving
- When flappy tach/popping noises would happen, I'd notice the car losing power for a split second
- Electrical systems stopped working during my drive (door open buzzer stopped working mid-way through the trip)
- Replaced the battery with a brand new one, no dice
- Power at the coil
- No spark at the plugs
Car is at a shop in PA - they will get to diagnosing it over the next few days. I'd prefer to fix myself, but I can't get it home from where it is without basic drivability.
Has anyone ever had this happen? Is the flappy tach a symptom of a larger electrical issue?
I found the post on adding the 2200uf capacitor to stop bouncing when changing RPMs rapidly, but I don't think this is that issue. Especially since the bouncy tach and the car dying are correlated (I think).
Would love to tap into the collective wisdom of the platform to help point me in the right direction.
emerygt350
post Feb 25 2023, 09:23 AM
Yeah, what do you have for ignition?
vjb206   Flappy, Bouncy, Wacky Tachometer?!   Feb 25 2023, 08:59 AM
Steve   My first guess would be the points or condenser.   Feb 25 2023, 09:14 AM
brant   Usually it’s the ignition points/cons. Does the...   Feb 25 2023, 09:21 AM
emerygt350   Yeah, what do you have for ignition?   Feb 25 2023, 09:23 AM
vjb206   You all are awesome, thank you so much for the qui...   Feb 25 2023, 12:08 PM
Jezibel   - generator light on in dash Just a periphera...   Apr 5 2024, 10:17 AM
Superhawk996   Given the generator light and other electrical iss...   Feb 25 2023, 12:28 PM
emerygt350   What superhawk said. Something is shorting causin...   Feb 25 2023, 12:43 PM
emerygt350   And the 123 is great but don't put it in there...   Feb 25 2023, 12:46 PM
ConeDodger   Short.   Feb 25 2023, 12:53 PM
fiacra   @vjb206 It has been a while since you started th...   Apr 5 2024, 11:53 AM
vjb206   So the wacky, bouncy tach (and red light) pictured...   Apr 9 2024, 11:35 AM
vjb206   And to @Superhawk996 's point, I will also l...   Apr 9 2024, 12:09 PM
brant   did you use a dwell meter when replacing the point...   Apr 9 2024, 12:30 PM
FlacaProductions   Why was the Tach-adapt put in by the PO? Curious ...   Apr 9 2024, 07:45 PM
Superhawk996   Burned points are typically related to: Bad conde...   Apr 9 2024, 08:00 PM
robkammer   Good morning teeters! Having just replaced a b...   Sep 18 2024, 07:29 AM
Superhawk996   Tach wire is black / purple   Sep 18 2024, 07:51 AM
robkammer   Thanks< I’ll check it out in the morning. Did...   Sep 18 2024, 02:56 PM
robkammer   Thanks< I’ll check it out in the morning. Did...   Sep 18 2024, 02:57 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 09:43 AM
