> Engine Compartment Blower Hose, L&R Where to Buy
NARP74
post Feb 21 2023, 10:54 AM
I borrowed this pic from @skota23 in another topic. Does anyone know where to buy the hoses like this? I have seen and tried others but they have issues and I wanted to try these.
malcolm2
post Feb 26 2023, 11:04 AM
i must have had a weak fan. Hoses were new and operational, fan was purchased used from here, and it did turn. whole car had been taken apart and re-worked, no holes in the threshold pipes either. (IMG:style_emoticons/default/piratenanner.gif)
Wonder what kinda flow is normal.
wonkipop
post Feb 26 2023, 11:58 AM
QUOTE(malcolm2 @ Feb 26 2023, 11:04 AM) *
gale force 2.
heaps.
sh#tload of air.
etc.
somethings up with yours.
as you pull the heater lever on the floor up, you should be opening the flaps in the heater boxes at the front end of the heat exchangers gradually more and more. cable operated from lever. this lets the hot air from the heat exchangers through and up the longs. its not until you pull the lever fully up that the fan kicks in. its a boost fan for low revs. like sitting at the lights. normally at higher revs cruising the engine cooling fan which is also connected to the system is providing sufficient air flow to push the air through the h e s and with the lever partly up to open the flapper valves to heat the car. the air flow from the cooling fan comes off two little valves with flaps the are off the side of the cooling fan casting on the underside and join to the h e.
not all type 4s had this engine bay boost fan.
i've seen a couple of south african 411s years ago that were in australia.
did not have the engine bay fan. hot climate car delete?
NARP74   Engine Compartment Blower Hose   Feb 21 2023, 10:54 AM
brant   watching this thread... I need one too.   Feb 21 2023, 11:22 AM
emerygt350   914rubber I believe. I bought some last year. Ex...   Feb 21 2023, 11:27 AM
NARP74   914rubber I believe. I bought some last year. E...   Feb 21 2023, 11:31 AM
914werke   I have heard that the longer hose can get sucked ...   Feb 21 2023, 12:56 PM
GregAmy   I tie-wrapped mine to a small bracket inserted und...   Feb 21 2023, 01:07 PM
NARP74   I tie-wrapped mine to a small bracket inserted un...   Feb 21 2023, 01:23 PM
930cabman   NAPA has it, found it there last year, fit perfect...   Feb 21 2023, 01:31 PM
Van B   NAPA has it, found it there last year, fit perfec...   Feb 21 2023, 09:13 PM
wonkipop   [quote name='930cabman' post='3059806' date='Feb ...   Feb 21 2023, 09:38 PM
930cabman   [quote name='930cabman' post='3059806' date='Feb ...   Feb 22 2023, 02:57 PM
wonkipop   [quote name='930cabman' post='3059806' date='Feb...   Feb 22 2023, 03:11 PM
930cabman   [quote name='930cabman' post='3059806' date='Feb ...   Feb 22 2023, 05:56 PM
NARP74   [quote name='930cabman' post='3059806' date='Feb...   Feb 22 2023, 06:35 PM
wonkipop   [quote name='Van B' post='3059955' date='Feb 21 ...   Feb 22 2023, 06:44 PM
930cabman   [quote name='930cabman' post='3060170' date='Feb ...   Feb 23 2023, 06:20 AM
Sprout   [quote name='930cabman' post='3060170' date='Feb ...   Feb 23 2023, 03:08 PM
Van B   [quote name='930cabman' post='3059806' date='Feb...   Feb 22 2023, 08:48 PM
wonkipop   [quote name='Van B' post='3059955' date='Feb 21 ...   Feb 22 2023, 09:20 PM
914werke   If found no one presently selling hoses that are t...   Feb 21 2023, 01:32 PM
wonkipop   ok i've dealt with this problem. 30 years ago...   Feb 21 2023, 04:37 PM
wonkipop   here is page from 411/412 parts catalogue. had it ...   Feb 21 2023, 05:35 PM
Type 47   I borrowed this pic from [b]@[url=http://www.91...   Feb 21 2023, 05:39 PM
NARP74   Maybe it is NLA, but the hose I saw there looked j...   Feb 21 2023, 05:46 PM
wonkipop   Maybe it is NLA, but the hose I saw there looked ...   Feb 21 2023, 05:58 PM
NARP74   I'll ask some of my sources to see what they m...   Feb 21 2023, 06:02 PM
wonkipop   I'll ask some of my sources to see what they ...   Feb 21 2023, 06:14 PM
71six   The complete fan blower assembly and hoses are mis...   Feb 21 2023, 06:48 PM
NARP74   The complete fan blower assembly and hoses are mi...   Feb 21 2023, 06:51 PM
wonkipop   The complete fan blower assembly and hoses are mi...   Feb 21 2023, 07:50 PM
bludden   I got my car with the fan not installed, and no ho...   Feb 21 2023, 09:43 PM
Jett   The initial OE hose is NLA and most of the old one...   Feb 21 2023, 10:04 PM
914Sixer   Here is what I am using. It is made for high heat...   Feb 22 2023, 07:04 AM
TheCabinetmaker   Bughaus has them.   Feb 22 2023, 07:33 AM
TheCabinetmaker   https://www.bughaus.com/beetle_hoses.htm   Feb 22 2023, 07:38 AM
NARP74   I feel like Veruca Salt in Charlie and the Chocola...   Feb 22 2023, 09:24 AM
wonkipop   I feel like Veruca Salt in Charlie and the Chocol...   Feb 22 2023, 03:40 PM
NARP74   CB Performance hose is 50mm, they do not have any ...   Feb 22 2023, 11:37 AM
zoomCat   Anyone have experience with the URO stuff? https:...   Feb 22 2023, 01:16 PM
ClayPerrine   Anyone have experience with the URO stuff? [url=...   Feb 22 2023, 01:33 PM
rhodyguy   They might look correct, but I wanted real heat. ...   Feb 22 2023, 02:16 PM
dr914@autoatlanta.com   we have plenty, early cars 70-72 use dissimilar si...   Feb 22 2023, 03:15 PM
NARP74   we have plenty, early cars 70-72 use dissimilar s...   Feb 23 2023, 10:20 AM
wonkipop   i also remember i developed a view on this change ...   Feb 22 2023, 04:04 PM
NARP74   WOW @wonkipop you got way further than I did...   Feb 22 2023, 04:04 PM
wonkipop   WOW [b]@[url=http://www.914world.com/bbs2/index....   Feb 22 2023, 04:17 PM
NARP74   WOW [b]@[url=http://www.914world.com/bbs2/index...   Feb 22 2023, 04:24 PM
wonkipop   interesting observation by dr. 914 of auto atlanta...   Feb 22 2023, 04:33 PM
NARP74   I agree @wonkipop I'll go by one in the nex...   Feb 22 2023, 07:34 PM
NARP74   Another group I am in, someone mentioned things li...   Feb 22 2023, 07:46 PM
Van B   Thank you kind sir. As much as I like the aluminum...   Feb 22 2023, 09:26 PM
wonkipop   Thank you kind sir. As much as I like the aluminu...   Feb 22 2023, 09:33 PM
Van B   Thank you kind sir. As much as I like the alumin...   Feb 22 2023, 09:45 PM
wonkipop   [quote name='wonkipop' post='3060238' date='Feb 2...   Feb 22 2023, 09:56 PM
Dave_Darling   I bought a 75-76 splitter for the fan on my 74. I...   Feb 23 2023, 01:01 AM
GregAmy   I have never seen a group of people get so intense...   Feb 23 2023, 11:00 AM
930cabman   I have never seen a group of people get so intens...   Feb 23 2023, 11:24 AM
914werke   I was thinking the same! 3 pages about a hose(...   Feb 23 2023, 11:08 AM
wonkipop   I was thinking the same! 3 pages about a hose...   Feb 23 2023, 07:32 PM
NARP74   Passion! I love it! It's learning an...   Feb 23 2023, 11:23 AM
rhodyguy   Parts person…‘Oh man, not AGAIN! The guy i...   Feb 23 2023, 11:54 AM
914Sixer   Realized I posted the wrong hose. Here is the 55m...   Feb 23 2023, 12:07 PM
NARP74   @Sprout Good confirmation   Feb 23 2023, 06:03 PM
Van B   Ha! Most of those pages are dead ends! A...   Feb 23 2023, 07:49 PM
914werke   Its nothing really special & could easily be d...   Feb 24 2023, 12:27 PM
NARP74   Its nothing really special & could easily be ...   Feb 24 2023, 12:35 PM
Mikey914   Funny thing is we have 2 camps her. The OEM hose i...   Feb 24 2023, 01:51 PM
NARP74   Funny thing is we have 2 camps her. The OEM hose ...   Feb 24 2023, 01:59 PM
NARP74   I'm not done flogging the equine yet!   Feb 24 2023, 02:02 PM
wonkipop   I'm not done flogging the equine yet! ...   Feb 24 2023, 03:15 PM
71six   So my mid year 1973 914 2.0 came from the west coa...   Feb 24 2023, 03:20 PM
NARP74   So my mid year 1973 914 2.0 came from the west co...   Feb 24 2023, 03:47 PM
914werke   Funny thing is we have 2 camps her. The OEM hose ...   Feb 24 2023, 04:30 PM
wonkipop   [quote name='Mikey914' post='3060648' date='Feb 2...   Feb 24 2023, 04:42 PM
rjames   I'm just posting here to try and get this thre...   Feb 24 2023, 05:11 PM
NARP74   I'm just posting here to try and get this thr...   Feb 24 2023, 05:17 PM
914werke   Well I was chasing an issue on MY car so.... pictu...   Feb 24 2023, 05:42 PM
914werke   Hose in question: 96.5cm nominal lenght   Feb 24 2023, 05:56 PM
NARP74   @914werke OK, thanks for the pic. My first time ...   Feb 24 2023, 06:06 PM
914werke   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 24 2023, 06:29 PM
wonkipop   turns out we are not the only ones out floggin hor...   Feb 24 2023, 07:02 PM
NARP74   @wonkipop That's hilarious. I never think to...   Feb 24 2023, 07:25 PM
NARP74   I ordered some of the napa/dorman hose, should be ...   Feb 25 2023, 06:44 PM
malcolm2   Maybe my fan was just crappy.... But I installed t...   Feb 26 2023, 08:49 AM
GregAmy   Does anyone find this fan option even works? Works...   Feb 26 2023, 08:58 AM
NARP74   @malcolm2 Both types of older hoses can crack, ge...   Feb 26 2023, 09:02 AM
malcolm2   i must have had a weak fan. Hoses were new and op...   Feb 26 2023, 11:04 AM
wonkipop   Wonder what kinda flow is normal. gale force...   Feb 26 2023, 11:58 AM
skota23   I think what I've learned here is that my hose...   Feb 27 2023, 01:09 PM
NARP74   I think what I've learned here is that my hos...   Feb 27 2023, 02:25 PM
NARP74   Sorry to reopen this, hopefully we don't get t...   Mar 4 2023, 01:15 PM
wonkipop   Sorry to reopen this, hopefully we don't get ...   Mar 4 2023, 05:17 PM
GregAmy   i hope this doesn't flick it over to 6 pages....   Mar 6 2023, 10:02 AM
NARP74   i hope this doesn't flick it over to 6 pages...   Mar 6 2023, 10:18 AM
GregAmy   [quote name='GregAmy' post='3062914' date='Mar 6 ...   Mar 6 2023, 10:30 AM
930cabman   Sorry to reopen this, hopefully we don't get ...   Mar 6 2023, 05:51 AM
NARP74   Sorry to reopen this, hopefully we don't get...   Mar 6 2023, 09:42 AM
930cabman   What was this all about anyways??   Mar 6 2023, 01:25 PM
NARP74   What was this all about anyways?? @930cabman I...   Mar 6 2023, 05:23 PM
GregAmy   Must...resist...keyboard...of death...   Mar 6 2023, 07:30 PM
41 User(s) are reading this topic (41 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 08:40 AM
