914/6 Headlight Relay Location, 914/6 Headlight Relay Location |
davenorcal |
Feb 26 2023, 08:14 AM
Newbie Group: Members Posts: 29 Joined: 5-June 21 From: Northern California Member No.: 25,605 Region Association: Northern California |
I cannot locate the high/low headlight relay on my 1970 914/6. By most accounts it lives on or near the fuse panel under the dash. I’ve looked everywhere and cannot find it, and before I start pulling the dash apart I’m hoping someone out there will enlighten me. The car is not stock…it is now a GT Tribute running a 3.2L. Here’s a pic of the fuse panel
BTW, What is up with nothing attached at position #3? I would love to hear opinions on that too. Attached thumbnail(s) |
davep |
Feb 26 2023, 04:54 PM
914 Historian Group: Benefactors Posts: 5,227 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
You should have a horn relay, and foglight relay, a buzzer and a flasher relay
The flasher is off the panel and is square with 4 blade terminals. The buzzer has only two terminal pins. The horn relay socket has the black/yellow wire for output The foglight socket has the white/yellow wire for output. The flasher does just that, it blinks, while the turnsignal switch directs the blinking to the turnsignals via the hazard switch which directs the blinking to just one side or to all the turnsignals. |
Lo-Fi Version | Time is now: 20th January 2025 - 11:01 AM |
