> 914/6 Headlight Relay Location, 914/6 Headlight Relay Location
davenorcal
post Feb 26 2023, 08:14 AM
I cannot locate the high/low headlight relay on my 1970 914/6. By most accounts it lives on or near the fuse panel under the dash. I’ve looked everywhere and cannot find it, and before I start pulling the dash apart I’m hoping someone out there will enlighten me. The car is not stock…it is now a GT Tribute running a 3.2L. Here’s a pic of the fuse panel
BTW, What is up with nothing attached at position #3? I would love to hear opinions on that too.
ClayPerrine
post Feb 26 2023, 06:36 PM
Also, the flasher relay does not mount to the fuse box mount. It goes into a hole in the dash frame near the ignition switch.
davenorcal   914/6 Headlight Relay Location   Feb 26 2023, 08:14 AM
Mikey914   Hazzard and turn signal are usually one in the sam...   Feb 26 2023, 08:31 AM
Cairo94507   Indeed, they are at the headlight motors- one on e...   Feb 26 2023, 08:35 AM
ClayPerrine   On a factory 914-6 there is no high/low beam relay...   Feb 26 2023, 09:14 AM
davep   You should have a horn relay, and foglight relay, ...   Feb 26 2023, 04:54 PM
ClayPerrine   Also, the flasher relay does not mount to the fuse...   Feb 26 2023, 06:36 PM
davenorcal   10-4 on the #3 position…you can see in my pictur...   Feb 26 2023, 07:24 PM
davep   This is a factory 914/6 and am I correct that its ...   Feb 27 2023, 05:28 AM
Dave_Darling   Have you checked your fuses? I think the Six runs...   Feb 26 2023, 09:29 PM
davenorcal   Yes, sir!   Feb 26 2023, 11:34 PM
davenorcal   I finished switching over to the @jwest fuse pan...   Mar 2 2023, 11:47 PM
peteinjp   #27 Combination relay (high/low) also the ground p...   Mar 3 2023, 02:58 AM
peteinjp   But regardless of whether or not you have the rela...   Mar 3 2023, 07:05 AM
ClayPerrine   Guys... A factory six does not have a headlight r...   Mar 3 2023, 03:19 PM
davenorcal   I’ll try tomorrow to check the headlight wires d...   Mar 4 2023, 12:02 PM
davenorcal   The high beam wire (white) was broken at the plast...   Mar 29 2023, 10:06 PM
ClayPerrine   Now to get my fog lights to come on without the ...   Mar 30 2023, 05:59 AM
davenorcal   Now to get my fog lights to come on without the...   Apr 3 2023, 10:21 PM
davep   The only reason that there is a fog light relay is...   Apr 4 2023, 09:26 AM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 20th January 2025 - 11:05 AM
