> 914/6 Headlight Relay Location, 914/6 Headlight Relay Location
davenorcal
post Feb 26 2023, 08:14 AM
I cannot locate the high/low headlight relay on my 1970 914/6. By most accounts it lives on or near the fuse panel under the dash. I’ve looked everywhere and cannot find it, and before I start pulling the dash apart I’m hoping someone out there will enlighten me. The car is not stock…it is now a GT Tribute running a 3.2L. Here’s a pic of the fuse panel
BTW, What is up with nothing attached at position #3? I would love to hear opinions on that too.
davenorcal
post Feb 26 2023, 07:24 PM
10-4 on the #3 position…you can see in my picture it’s combined. Whew!
This is a factory 914/6 and am I correct that its fuse panel does not look like the /4 panel?
I labeled these relays after removing each one at a time to see what still worked and did not. Let me walk through that:
- Removing the Black Square relay only affected the hazard flashers (it wouldn’t work) yet the turn indicators still worked. That’s why I crossed out “turn sig”.
- Round one that I marked “turn” was removed and the turn indicators stopped working, but the hazard lights worked. The part number indicates a generic all-purpose relay
- Next Round one seems only to impact the fog lights. This is the same generic all-purpose relay.
- Last Round one is a buzzer that supposed to work if the key is left in the ignition. Part number confirmed that. The “Fuel” label is just wrong.
What started all this is my left headlight goes out when I turn on my high beams. I figured a quick swap of the relay would do the trick (wherever it is), and while I’m at it I was going to install a new @Jwest fuse panel, AND get my fog light to work without my headlights on. I wanted to do one thing at a time so if something went wrong I would know what I screwed up.
@ClayPerrine and @davep - Your comments about the square relay make sense since it was not attached to the fuse panel and the wires look too short to do that anyway.
Does this change anyone’s advice?
davenorcal   914/6 Headlight Relay Location   Feb 26 2023, 08:14 AM
Mikey914   Hazzard and turn signal are usually one in the sam...   Feb 26 2023, 08:31 AM
Cairo94507   Indeed, they are at the headlight motors- one on e...   Feb 26 2023, 08:35 AM
ClayPerrine   On a factory 914-6 there is no high/low beam relay...   Feb 26 2023, 09:14 AM
davep   You should have a horn relay, and foglight relay, ...   Feb 26 2023, 04:54 PM
ClayPerrine   Also, the flasher relay does not mount to the fuse...   Feb 26 2023, 06:36 PM
davenorcal   10-4 on the #3 position…you can see in my pictur...   Feb 26 2023, 07:24 PM
davep   This is a factory 914/6 and am I correct that its ...   Feb 27 2023, 05:28 AM
Dave_Darling   Have you checked your fuses? I think the Six runs...   Feb 26 2023, 09:29 PM
davenorcal   Yes, sir!   Feb 26 2023, 11:34 PM
davenorcal   I finished switching over to the @jwest fuse pan...   Mar 2 2023, 11:47 PM
peteinjp   #27 Combination relay (high/low) also the ground p...   Mar 3 2023, 02:58 AM
peteinjp   But regardless of whether or not you have the rela...   Mar 3 2023, 07:05 AM
ClayPerrine   Guys... A factory six does not have a headlight r...   Mar 3 2023, 03:19 PM
davenorcal   I’ll try tomorrow to check the headlight wires d...   Mar 4 2023, 12:02 PM
davenorcal   The high beam wire (white) was broken at the plast...   Mar 29 2023, 10:06 PM
ClayPerrine   Now to get my fog lights to come on without the ...   Mar 30 2023, 05:59 AM
davenorcal   Now to get my fog lights to come on without the...   Apr 3 2023, 10:21 PM
davep   The only reason that there is a fog light relay is...   Apr 4 2023, 09:26 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 20th January 2025 - 10:59 AM
