installing Dakota Digital CHT, I got some questions... |
914 RZ-1 |
Mar 6 2023, 08:48 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm getting ready to install a Dakota Digital CHT. Here are my questions:
1. What is the shrink wrap for on the copper wire? Mine came with it as shown in the photo. Do I shrink it once installed? It seems too big to shrink down over the wire. 2. I'm installing this on #3 cylinder. Looks like I'll have to bend the spark plug connector. Has anyone done this, or must I grind out a space for it? 3. What circuit should I install this on at the fuse box? The red wire goes to "fused +12V with key on". 4. Is the blue night dimming input required? If so, where does it go on the fuse box? 5. Any tips for running the wire in the engine bay? I was planning on running the wire from the firewall on the driver's side, to the trunk wall, then along that to the #3 cylinder location. The other way would be along the fire wall, but then wires have to cross over the engine and a bunch of other spaghetti to get to #3. Thanks! -Jeff ---------- Attached thumbnail(s) |
914 RZ-1 |
Mar 10 2023, 07:13 PM
Back to my question:
I bent the connector. I was able to screw on the spark plug by hand. How do I tell if it's seated properly? I don't want to tighten it with a wrench only to find I've mangled it. I can't see in there very well. Any tips or tricks for seeing in there? I'd like to hear from those of you who did not take the engine out. Thanks! |
Lo-Fi Version | Time is now: 26th September 2024 - 11:52 AM |
