installing Dakota Digital CHT, I got some questions... |
914 RZ-1 |
Mar 6 2023, 08:48 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm getting ready to install a Dakota Digital CHT. Here are my questions:
1. What is the shrink wrap for on the copper wire? Mine came with it as shown in the photo. Do I shrink it once installed? It seems too big to shrink down over the wire. 2. I'm installing this on #3 cylinder. Looks like I'll have to bend the spark plug connector. Has anyone done this, or must I grind out a space for it? 3. What circuit should I install this on at the fuse box? The red wire goes to "fused +12V with key on". 4. Is the blue night dimming input required? If so, where does it go on the fuse box? 5. Any tips for running the wire in the engine bay? I was planning on running the wire from the firewall on the driver's side, to the trunk wall, then along that to the #3 cylinder location. The other way would be along the fire wall, but then wires have to cross over the engine and a bunch of other spaghetti to get to #3. Thanks! -Jeff ---------- Attached thumbnail(s) |
FlacaProductions |
Mar 11 2023, 11:19 AM
Senior Member Group: Members Posts: 1,649 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I bent mine, screwed in the plug by hand until it resisted and then put the socket on it and gently snugged it up. I dunno...it just felt right and the depth looked right and the engine ran fine and the gauge read right. I could see that the wire hadn't spun so i called it good.
914 RZ-1 |
Mar 11 2023, 02:58 PM
I bent mine, screwed in the plug by hand until it resisted and then put the socket on it and gently snugged it up. I dunno...it just felt right and the depth looked right and the engine ran fine and the gauge read right. I could see that the wire hadn't spun so i called it good. Yeah, I decided to do the same thing. I screwed in the plug by hand to make sure I wasn't cross-threading it, then put the socket on and continued by hand until it was too hard to turn, then gently turned it with the wrench until snug. It would be nice to have a much wider hole there, with a rubber seal to match, so we could see in there better. |
Lo-Fi Version | Time is now: 28th June 2024 - 04:00 PM |
