East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
I’ve been out of the 914 game for quite some time. The last 914 I built was back in 2006 and was quite a build. I’ve had about a dozen 914s over the years and my 2006 build was to be my ultimate 914 (for me at least). It was a GT flared 3.6 six conversion and was a great car. I sold it in 2015 and moved to other things. I’ve been getting the itch to build another teener for a while, but to go in a different direction. I’ve seen a couple Safari builds and that seemed interesting.
I picked up pretty well worn ‘72 914 for the base of my project. My plan is to build a budget conscious (it’s all relative) Subaru powered Safari mod. I plan to go with a normally aspirated 2.5 Subaru from a 1998 Forrester along with the Subaru tranny. I’ve been working on removing rust and getting the tub suitable for my plans. This will by no means be a concours resto type build, but should prove interesting. Here’s the base car being picked up for the project start ![]() I stripped it down and sold the engine and tranny (it was a partially completed V8 conversion). Then started cutting out rusted areas a welding in new metal. Some Radom rust repair pics in no special order…. ![]() Attached thumbnail(s) ![]() |
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 636 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Some great fabrication there. Rack design coming along, clearly you'll need to mount 2 spare tires up there at a minimum (IMG:style_emoticons/default/smile.gif)
I'm sure you've thought ahead for this; but one thing to check is that the driveshafts are still OK under full droop? No doubt you can account for the 2" lower arms in the trans cradle design/mounting... - Tony |
East coaster |
Some great fabrication there. Rack design coming along, clearly you'll need to mount 2 spare tires up there at a minimum (IMG:style_emoticons/default/smile.gif) I'm sure you've thought ahead for this; but one thing to check is that the driveshafts are still OK under full droop? No doubt you can account for the 2" lower arms in the trans cradle design/mounting... - Tony Thanks! The axle clearance is a concern, but it seems others have tread down this path and I haven’t heard of an issue. That said, I won’t sleep easy until it’s all installed and proven. I’ve thought about what I’ll do if it’s an issue, but hoping it’s not. |
Lo-Fi Version | Time is now: 2nd April 2025 - 03:08 AM |
