What went wrong?, it was running great and then not at all |
Type 47 |
Mar 15 2023, 03:59 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
so we put the original 62k engine back in that had not had the distributor removed. Adjusted the valves (again after we put about 10 miles on it) we rebuilt the Webbers and it fired up. We did some timing and tweaking on the carbs.
It ran OK but a little shy of perfect. I replaced the wires and it seemed to improve it but idled a little high around 1,200. My son came over to work on it the next day, but I wasn't home. All of a sudden, it won't even run. we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) my son says we have spark, too much fuel, and not enough air. What do we do next????? |
930cabman |
Mar 15 2023, 04:38 PM
Advanced Member Group: Members Posts: 3,772 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Is there compression?
Superhawk996 |
Mar 15 2023, 04:41 PM
914 Guru Group: Members Posts: 6,589 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Is there compression? (IMG:style_emoticons/default/biggrin.gif) I ASSUMED . . . Good call Three things to run: Fuel Compression Spark Verify everything |
Lo-Fi Version | Time is now: 21st December 2024 - 06:14 AM |
