What went wrong?, it was running great and then not at all |
Type 47 |
Mar 15 2023, 03:59 PM
Senior Member Group: Members Posts: 788 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
so we put the original 62k engine back in that had not had the distributor removed. Adjusted the valves (again after we put about 10 miles on it) we rebuilt the Webbers and it fired up. We did some timing and tweaking on the carbs.
It ran OK but a little shy of perfect. I replaced the wires and it seemed to improve it but idled a little high around 1,200. My son came over to work on it the next day, but I wasn't home. All of a sudden, it won't even run. we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) my son says we have spark, too much fuel, and not enough air. What do we do next????? |
ChrisFoley |
Mar 20 2023, 06:35 PM
I am Tangerine Racing Group: Members Posts: 7,967 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
with a timing light while the engine is running.
Type 47 |
Mar 20 2023, 08:23 PM
with a timing light while the engine is running. We did get it running, kind of. So we used a timing light. But i'm not sure how to use it. I was able to hold rpm at 3,500 while it was scoped and the mark was there. not sure how to related that to a static timing of 7.5 degrees. engine is still popping and backfiring like it was originally. it was running so good, getting a little discouraged. BTW, did the test on the lift plate and all is good! |
Lo-Fi Version | Time is now: 21st December 2024 - 05:58 AM |
