> Reverse light switch smoking when ignition turned on
iwuzazombie
post Mar 24 2023, 06:20 PM
Hello! My reverse light switch is smoking when ignition is turned on and the #4 fuse blows. Bad switch or what else may cause that? Thanks!
Edit: looks like these wire connectors are bad. Can they be replaced?
Update:
1. everything seemed fine in the car, starting, a few minor electrical weirdness like both blinkers blinking after a second of using them (could be just wrong bulbs i hadn't checked yet) and dash/center console lights not working
2. fuse #4 started blowing and i could smell the electrical smoke
3. went through alot of fuses trying to troubleshoot the problem, checked all the grounds including the tail lights and license plate lights as on forums alot of mentions about those potentially being culprit
4. finally found the reverse switch was smoking, took out the wires which look terrible (as seen in the picture) and then fuse #4 stopped blowing
5. now car turns over but won't start
6. gonna pull the switch today and inspect it and try to replace those male bullet connectors (what a bad design btw!!!)
Could bad connection at that reverse switch cause the car to not start?
flipb
post Mar 25 2023, 02:40 PM
Didn't reconnect the transmission ground strap? Infamous dr914@autoatlanta.com mistake.
iwuzazombie
post Mar 25 2023, 03:42 PM
QUOTE(flipb @ Mar 25 2023, 01:40 PM) *
It was running fine after I got it back. Fuse #4 was blowing after that which I finally traced to the reverse light switch, which was literally smoking. Up until minutes before I found that which took me a while and blew thru a bunch of fuses the car was starting fine. Once I found that, I pulled those really bad wires out and at that long the car no longer would start. (IMG:style_emoticons/default/sad.gif)
IronHillRestorations
post Mar 25 2023, 05:24 PM
I. I. R. C.
QUOTE(iwuzazombie @ Mar 25 2023, 01:42 PM) *
I’m going to bet that if you look up a the underside of the trunk floor, you will find the ground strap isn’t bolted to the ground buss. If so take a picture, call the shop and tell them they’ve created a problem. The starter grounds through the transmission via the ground strap. No ground and the starter will use whatever path it finds. Typically it’s the clutch cable.
The reverse switch should never get hot like that.
iwuzazombie
post Mar 25 2023, 05:52 PM
QUOTE(IronHillRestorations @ Mar 25 2023, 04:24 PM) *
That was one of the grounds I checked actually when troubleshooting the blown fuse. I removed it, cleaned it up and put it back on. It was connected from after the
Shop.
iwuzazombie   Reverse light switch smoking when ignition turned on   Mar 24 2023, 06:20 PM
JeffBowlsby   Is your ignition harness 12-pin connector recently...   Mar 24 2023, 07:45 PM
iwuzazombie   Is your ignition harness 12-pin connector recentl...   Mar 24 2023, 09:35 PM
bkrantz   Sounds like something is grounded that should not ...   Mar 24 2023, 09:05 PM
iwuzazombie   Sounds like something is grounded that should not...   Mar 24 2023, 09:13 PM
Spoke   No the fuse doesn’t blow when the wires are dis...   Mar 24 2023, 11:28 PM
Geezer914   I bought the Porsche wire connectors from Pelican ...   Mar 25 2023, 01:06 AM
Mikey914   May be as simple as an ignition switch failure?   Mar 25 2023, 01:51 AM
iwuzazombie   May be as simple as an ignition switch failure? ...   Mar 25 2023, 09:00 AM
davep   No, I doubt the ignition switch would be in play. ...   Mar 25 2023, 09:04 AM
iwuzazombie   No, I doubt the ignition switch would be in play....   Mar 25 2023, 09:51 AM
IronHillRestorations   My guess is that the shop incorrectly plugged in t...   Mar 25 2023, 12:13 PM
iwuzazombie   My guess is that the shop incorrectly plugged in ...   Mar 25 2023, 01:53 PM
IronHillRestorations   My guess is that the shop incorrectly plugged in...   Mar 25 2023, 02:03 PM
jim_hoyland   [quote name='iwuzazombie' post='3067603' date='Ma...   Mar 25 2023, 02:14 PM
flipb   Didn't reconnect the transmission ground strap...   Mar 25 2023, 02:40 PM
iwuzazombie   Didn't reconnect the transmission ground stra...   Mar 25 2023, 03:42 PM
IronHillRestorations   Didn't reconnect the transmission ground str...   Mar 25 2023, 05:24 PM
iwuzazombie   [quote name='iwuzazombie' post='3067618' date='Ma...   Mar 25 2023, 05:52 PM
IronHillRestorations   Didn't reconnect the transmission ground stra...   Mar 25 2023, 04:25 PM
iwuzazombie   Didn't reconnect the transmission ground stra...   Mar 25 2023, 05:50 PM
- Lo-Fi Version Time is now: 6th January 2025 - 06:47 PM
